Bad vacuum leak, question...
Re: Bad vacuum leak, question... (JRChurch)
it sure will...
itll cuase a horrible stumble.....
when my booster blew up, the car would hardly idle...
well 1st thing u do swap out the plugs/ wires etc..
then check the timing... (including total advance...) see if your dist is working right..
then AFTER u make sure the timing is correct then u check the vacuum with a vacc guage....
incorrect timing will effect vacuum./
