Brake Booster Vacuum Leak..Autozone says.... True or False?
Re: Brake Booster Vacuum Leak..Autozone says.... True or False? (JRChurch)
in your previous post you said you have a vacuum leak in the booster..
so replace the booster...
you also said you have a leaking mastercylinder...(inner seal)
so replace the mastercylinder.....
Re: Brake Booster Vacuum Leak..Autozone says.... True or False? (daily_driver)
do u have a vacuum guage??
hook it up to the manifold line..
now observe the #...
now unhook the vacuum line going to the brake booster and plug it with your finger...
read guage.
if the guage reads higher then indeed you have a leak and it needs to be replaced.
read guage.
C6 the C5 of tomorrow
Do'nt forget the Autozone booster is not 'correct' for you car. So keep the old one around, or better yet they can be repaired!
