tach drive is in and msd box
alittle update thanks to x-otic and 74vette the tach drive distributor is in and the msd box also and the tach now works finally..also very quick startup and very smooth pulling power..im still working on the springs and advance..needs more in alittle quicker..they shorted one light spring so ill have to get one more..I cant believe the springs they put in there from msd...they look like big block coil springs..huge...also have the little miss back..really a flutter but we found that too carb isnt sealing right to the intake the nitrous plate...so when i installe the rpm airgap intake that should be fine..but guys your right very nice stuff...and again thanks to x-otic and 74vette(chris)for helping out.
Re: tach drive is in and msd box (pats406nitrovette)
After seeing Pats MSD setup I going to change over to MSD distributor and MSD box. Like Pat said "It real nice stuff" :cool:
As said before, definitely quality parts!
Pat:
I will be purchasing an MSD 6AL Ignition Box in the near future and was just wondering where you ended up mounting your box at? Thanks.
Re: tach drive is in and msd box (bence13_33)
i mounted it just above the pass. side control arm on the fender well ill take pics tommorrow and post them tommorow night looks good and out of the wy.
hey bence....looks great where it is, banging my head for not putting mine there!
Chris
[Modified by 74VETTE, 8:53 PM 12/16/2001]
Chris
