Tie rod end removal question
Is there a trick to getting the inner tie rod end off of the control arm?
I've gotten the steering knuckle off and the outer tie rod end, but there is no way to swing a hammer to get the tie rod threaded end out of the control arm.
Any ideas?
Any ideas?
Re: Tie rod end removal question (phoenix)
Use a tie rod end puller (which is less likely to damage your tie-rod anyway). You can usually borrow these from auto parts stores.
Senior Member since 1492
Any ideas?
Any ideas?
The outer tie rod connects to the steering knuckle.
Re: Tie rod end removal question (1970 Stingray)
Yea, I meant the steering link.
Thanks. I think that autozone has loaner tie rod end pullers.
