Old 03-05-2015, 06:14 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: General How-Tos
Print Wikipost
Dealer Latch Bulletin (roof popping noise)
Old 05-03-2008, 02:47 PM
Danlando
Danlando's Avatar
Default Dealer Latch Bulletin (roof popping noise)
I searched and haven't seen a very recent thread on the ubiquitous "roof popping" issue, so I will post this in hope I'm not repeating something already discussed.
My local dealer says they have both the GM bulletin and the parts in inventory to solve the roof noise issue. Some kind of a clip or plunger probably similar to the solution offered by a CF member back in May. Snaps onto the front roof lever right next to the roller, which is said to be the culprit.
So if you don't want to DIY, your dealer should be able to fix it while you wait.
Dan
Old 05-03-2008, 02:59 PM
2 GRUMPY
2 GRUMPY's Avatar
Dan,I found a thread on this,search for thread titled,
'New Approach to fixing top popping noise" by mtoner
3-2-08
It has pictures to show you how to cure this.
Old 05-03-2008, 04:48 PM
kenrobb
kenrobb's Avatar
In hearing some talk at BG Bash, GM will have a factory "fix" out in a replacement handle the end of May. A new "roller" will be in place that won't roll or slide to make the popping noise. I did the C clip on mine and the top didn't pop 800 miles to BG. But I put the 2 handles off my car on my buddies in BG, it didn't pop on way home but begin popping the next day he says. One cheap fix is to apply some epoxy like J-B weld to the area under the roller to fix it in place. This is what GM is doing for temp fix handles they were showing at BG Bash. My GM "replacement" handles didn't pop on way home from BG.
Old 05-03-2008, 05:15 PM
Danlando
Danlando's Avatar
The GM fix is in right now according to my dealer. In the meantime, a small shot of silicone did the trick.
Old 05-03-2008, 06:03 PM
2 GRUMPY
2 GRUMPY's Avatar
Default Popping Top !!!
I met the engineer from GM who designed the tops on both the Coupe's and the Vert's at the Bash and he replaced my handles on my Coupe right there in the Museum parking area ! I drove back home to the Memphis area around 250 miles and it DID NOT POP ONCE !!! He said they had to redesign the round roller so it would have a flat surface in the back so it will lock in place and not roll .The original design after a period of time and tension would roll and not hold the tension tight enought and this was causing the popping you heard.He said the new handles are out there and the dealers should have them by now!
HEY KENROBB,Thanks for telling me about this at the Bash !! How are you and BOB doing ?
Old 05-03-2008, 06:27 PM
vmax1200
vmax1200's Avatar
question my vette was just built last week do you know if the problem has been fixed at the factory level yet?..thanks Scott
Old 05-03-2008, 06:36 PM
2 GRUMPY
2 GRUMPY's Avatar
VMAX1200 ,I'm not sure about the newer models ?
Old 05-03-2008, 06:42 PM
danl72
danl72's Avatar
It was a problem with '05's and some '06's. I don't think there were any issues with '07 or '08. But I could be wrong. It wouldn't be the first time.
Old 05-03-2008, 06:47 PM
statman
statman's Avatar
NoCA Events Coordinator
Good question. Can anyone who has recently taken delivery of an ordered car verify if it has been taken care of? My coupe is scheduled to be built the week after next, so I can't report on this for a few weeks.
Old 05-03-2008, 06:50 PM
dgrant3830
dgrant3830's Avatar
Wounded Warrior Escort '11
Sounds like the fix is to the roof panels themselves then or am I messed up? I've got the dual roof option so will probably require both to be fixed if I understand correctly. If I didn't, I've got the flame suit on so fire away!
Old 05-03-2008, 07:01 PM
Ozone
Ozone's Avatar
No flame suit necessary! I think the problem has always been with the painted tops. I haven't heard of any popping problems with the transparent top.
Old 05-03-2008, 07:30 PM
hdwideglide
Support Corvetteforum!
hdwideglide's Avatar
My 07 has been in twice for the popping noise. I took in last week in hopes of the new fix. I think I was to early. Still pops.
Old 05-03-2008, 08:45 PM
rbrcs
rbrcs's Avatar
Just got an 08, 200 miles so far and no noise from the top
not08crmanymore
not08crmanymore's Avatar
Are you guys talking about the noise with the top on or off and in the back??SQUEAKING or POPPING?thanks.
Old 05-03-2008, 08:55 PM
El Dorado
El Dorado's Avatar
St. Jude Donor '08
I picked up my '08 in March and it popped a bunch, did the c clip and it only pops on occasion........ time to bring it in for the new "FIX"
Old 05-03-2008, 10:39 PM
Vettin08
Vettin08's Avatar
I'll be there Thursday, I'll ask if you want.
Old 05-04-2008, 12:04 AM
HorsePower Junkie
HorsePower Junkie's Avatar
St. Jude Donor '20-'21-'22-'23
Dan
Dan,
See if you can get the bulletin number and/or the new latch part number please from your dealer.
Thanks
To Dealer Latch Bulletin (roof popping noise)
Old 05-04-2008, 10:05 AM
Blue Demon
Blue Demon's Avatar
Location: And then it was said... "let there be blue Corvettes and yellow Camaros" Ft Worth Texas
Cruise-In IV Veteran
St. Jude Donor '09
The transparent top on my 2006 sounds like popcorn popping on a warm day. I'll be calling my dealer tomorrow about the fix.
Old 05-04-2008, 10:10 AM
not08crmanymore
Blue Demon is online now Report Post Reply With Quote
That might be the SHIMS they put in after the fact on alot of 05 + vettes w/glass tops.TSB out there somewhere..
Old 05-04-2008, 10:39 AM
joeking
joeking's Avatar
Cruise-In II Veteran
Cruise-In III Veteran
My glass top also makes some popping noises.
Quick Reply: Dealer Latch Bulletin (roof popping noise)
