X-Pipe vs. H-Pipe
Old 12-16-2001, 01:41 AM
Blake-73
Blake-73's Avatar
Default X-Pipe vs. H-Pipe
Trying to decide which way to go. Which one would reduce sound the most. I am trying to lessen the noise a bit, plus pick up some performance. Anyone have experience with both setups?
Blake-73
Old 12-16-2001, 02:10 AM
LT1driver
LT1driver's Avatar
Default Re: X-Pipe vs. H-Pipe (Blake-73)
The X pipe is best, but H pipe also works just not quite as efficient. :cheers:
Old 12-16-2001, 02:13 AM
AlwaysWave
AlwaysWave's Avatar
Cruise-In III Veteran
Default Re: X-Pipe vs. H-Pipe (LT1driver)
look at my 2nd post in your H-pipe thread. :)
Old 12-16-2001, 09:43 AM
flynhi
flynhi's Avatar
X pipe will reduce exhaust sound more than h pipe. It will also raise the pitch an octave or two.
Old 12-16-2001, 10:11 AM
fireball
fireball's Avatar
I scanned this drag / dyno comparison of different exhaust setups...
http://www.corvetteforum.net/c3/fireball/vette/
Here's the dyno summary:
Open headers: 429hp / 384tq
Dual exhaust: 412hp / 371tq
H - Pipe: 419hp / 378tq
X - Pipe: 428hp / 391tq
Old 12-17-2001, 12:11 AM
Blake-73
Blake-73's Avatar
Default Re: X-Pipe vs. H-Pipe (fireball)
Thanks for the replys. I got this on me "to do list" now.
Blaek-73
Old 12-17-2001, 01:25 AM
tzavaleta
tzavaleta's Avatar
Will an X-pipe fit on a C3? Does anyone (maybe Flowmaster) make a pre-fabbed kit?
Old 12-17-2001, 01:48 PM
John Dirks
John Dirks's Avatar
Default Re: X-Pipe vs. H-Pipe (tzavaleta)
I am thinking of doing this mod also. Anyone else have experience with this?
Old 12-17-2001, 02:02 PM
marky mark
marky mark's Avatar
Default Re: X-Pipe vs. H-Pipe (John Dirks)
Dr Gas, I believe is the name. X pipe will fit C-3's. I have a 2&1/2" version located right behind crossmember on a '69. Previous comments on power & sound are similar to my results. I would recommend X pipe from Dr. Gas.
Regards, Mark :flag :chevy
Old 12-17-2001, 02:04 PM
CDaniel525
CDaniel525's Avatar
Default Re: X-Pipe vs. H-Pipe (marky mark)
dr. gas.....anyone know of a website or phone number??
Chris
Old 12-17-2001, 02:40 PM
John Dirks
John Dirks's Avatar
Default Re: X-Pipe vs. H-Pipe (74VETTE)
How much is the X pipe from Dr Gas? how difficult is the install? Could a decent muffler shop fabricate a similar product?
Old 12-17-2001, 03:48 PM
Alwyn678
Alwyn678's Avatar
Wow those are pretty good GAINS!! with the X Pipe
Old 12-17-2001, 04:01 PM
damac
damac's Avatar
Default Re: X-Pipe vs. H-Pipe (Alwyn678)
Marky Mark,
I went to the Dr. Gas webpage and saw the x-pipes. It did not appear that they had a kit specifically for corvettes. Did you buy a corvette specific kit or did you just use their x-pipe and have some pipes bent for it?
Thanks,
Mike
Old 12-17-2001, 05:00 PM
flynhi
flynhi's Avatar
Default Re: X-Pipe vs. H-Pipe (damac)
Made my own from two 45 degree mandrel bends. It took quite a while to determine the points of intersection and then to get it welded and smoothed inside. I don't think a muffler shop could make as well or as cheaply as Dr. Gas.
Old 12-17-2001, 05:58 PM
GROSSPOLLUTER60
GROSSPOLLUTER60's Avatar
Default Re: X-Pipe vs. H-Pipe (flynhi)
I'm using a Dr Gas 3' to 2.5 X-pipe and a complete mandrel bent system through Flowmaster delta flows. I have n dyno #'s but It works REAL well with my engine setup.
For a short MPEG go to http://home.earthlink.net/~hjnsn and click on GP6T.
My buddies Mustang has a 347 with the same exhaust system as well and it runs REAL HARD :cool:
Old 12-18-2001, 05:47 AM
marky mark
marky mark's Avatar
Default Re: X-Pipe vs. H-Pipe (GROSSPOLLUTER60)
The best idea is to buy just the X-pipe itself and have the other pipes fabricated by a good muffler shop. I bought a "kit" and wound up not using the supplied pipes (they weren't Corvette specific and did not fit exactly right).
Don't remember the web address, if you still haven't found it by now post here and I'll dig through my old receipts file for the ph. #.
No way you can get one built better at a muffler shop than their version. They've done the R & D and have got a sweet little product that works. They supply most of NASCAR with them. This is a cheap (relatively) power increase.
Regards,Mark :flag :chevy
To X-Pipe vs. H-Pipe
Quick Reply: X-Pipe vs. H-Pipe
