UPDATE #5 ***Suspension wrap up and BREMBO's!: LG Motorsport/JMac Racing***
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Hi guys,
JMac Racing project update #5 is here!
Suspension and Brakes are finished, installed, and fully tested now.
Tech Specs. on the suspension:
We have three different sets of wheels and tires to choose from on this combo, depending on track conditions, or event rules.
Assembled Front Suspension
Assembled Rear Suspension
Braking is being handled by Brembo on this car.
Using Brembo's new Monoblock GT package, a 355mm x 32mm two piece floating, slotted rotor is fitted to the front. Clamping down on this is a monoblock 6 piston caliper finished in red. The rear uses a 345mm x 28mm two piece floating, slotted rotor. Rear calipers are 4 piston monoblock, again finished in red.
Braking Specs:
6 Piston Close Up
Brembo GT Mono Block 4 wheel brake kit
ForgeLine ZX3R with Hoosier R6
CCW with full slick
Engine Modifications up next, and a sneak peak on the track!
PROJECT HISTORY
PROJECT START
Project Start
UPDATE #2:
Base Line Dyno
UPDATE #3:
Suspension Start
UPDATE #4:
Suspension Update
- LG Mono Ball Control Arms
- LG Billet Drop Spindles
- GM Racing Wheel Bearings
- ARP wheel studs
- LG 4 wheel Coil Overs
- GM T1 Sway bars
- LG Quiet End Links
- LG Bump Steer kit
- Polished GM Z06 wheels with GoodYear RunFlats
- ForgeLine ZX3R 18/19 combo wrapped in Hoosier DOT R6 (295/345)
- CCW Corsair 18/18 combo wrapped in full Slicks
Braking Specs:
- Brembo MonoBlock 6 piston front caliper
- Brembo MonoBlock 4 piston rear caliper
- 355mm x 32mm front rotors
- 345mm x 28mm rear rotors
- LG 14" spindle ducts
- 3" hose ducting from nose to spindle duct
6 Piston Close Up
CCW with full slick
PROJECT HISTORY
PROJECT START
Project Start
UPDATE #2:
Base Line Dyno
UPDATE #3:
Suspension Start
UPDATE #4:
Suspension Update
Premium Supporting Vendor
St. Jude Vendor Donor '03-'04-'05-'06-'07-'08-'09-'10-'11
Here is what I posted in another thread about this car, and I think the customer chose his brakes:
Hi guys,
Well, I drove the car and I can tell you that after I passed the Galardo and left it behind, I can truly say that this car handles like our World Challenge car but drives like a street car. It is probably about 6-8 seconds faster than a stock z at this small track. it is easily capable of sub 1:19 second laps in good hands.
The car was so good that I am going to do the same mods to my own Z06 as soon as I have time.
The tires that I ran on were the Hoosiers. I am basing all my comments on how the Hoosiers were.
The brake pads were a combination of two brands, Ferodo and Pagid, but that was only because we had to get some Cobalt pads built custom, which we did. And in spite of that, the brakes were flawless with no pedal issues at all.
The Brembo brakes were the customer's brake of choice and it was a good choice. They worked well.
We had our Spindle ducts installed and some custom inlets in the stock location under the splitter/undertray. Again, they worked great.
The custom dry sump tank and pan were also a success, as was our dual oil coolers, which included the stock cooler in series with our LG Super Cool radiator.
We also have a kit for the rear diff cooler on the Z06 also.
At anyrate, from the front to the back, the car was a total success in every respect. Our LG Coil over package with Hypercoil springs did their usual perfect job controlling the suspensiosn and eating the bumps with our Aluminum Bilstein shocks with our World Challenge valving.
And the aero package was dialed in and balanced very well. We left a touch of high speed understeer in it to be on the safe side.
Our LG Drop Spindles as we used in the World Challenge race car not only drop the car without upsetting the suspension geometry also worked as expected. The beauty of the drop spindles is that they not only lower the car and keep the geometry but they add camber and cure the bumpsteer easily as installed.
All in all, the car was a hoot to drive. When I stop racing, i plan on doing plenty of track days with a car like this to get my fix.
Thanks guys,
Lou Gigliotti LGM
Hi guys,
Thanks guys,
Lou Gigliotti LGM
__________________
LG Pro LT Headers, MOST HP, MOST TORQUE
http://lgmotorsports.com/gallery/alb...no_compare.jpg
LGM http://www.LGMotorsports.com
Winner Daytona 250
22 WC Wins
"Most powerful Corvette headers on the planet"
Winner Daytona 250
22 WC Wins
I want to know more about those wheelbearings. I imagine my car is about due for some, and if not now, the recent suspension mods will push the old ones over the edge. PM me with pricing, or source, of you are willing to share. Thanks.
Anthony,
Is that bumpsteer kit an LGM product? What's the cost for forum members (please PM me, if it can't be listed here)?
Finally, what's the cost and availability of those wheelbearings?
Thanks!
Thanks!
