Anyone see that dual 11" BeCool Fan in Jegs????
Cruise-In VII Veteran
St. Jude Donor '07
I was thumbing through Jegs during a sitdown and noticed a dual 11" fan set up for a little over $200.00 with mounts. That seems like a deal for duals?
Re: Anyone see that dual 11" BeCool Fan in Jegs???? (Budman78)
I dunno about a deal, but does it come with all the wires and switches and stuff?
If so I've seen them go for $375...if thats the case then its a good deal, IMO
Daniel
Daniel
The BeCool unit looks nice but I'm not sure that it will fit between the radiator and the left suspension.
DeWitt's has the Spal unit on sale right now also.
FWIW: I've got the dual Flex-a-Lite fans and I'm still watching the prices of other units.
Re: Anyone see that dual 11" BeCool Fan in Jegs???? (1979toy)
I saw the fans from BeCool in Jegs also. From the looks of them I believe they are Spal's. It looks a good price, unless you go for the chrome ones. They seem a little high.
John
John
Isn't the BeCool cfm rating lower than the SPAL? It was the last time I checked.
Also try http://www.haywireinc.com/products.asp, seems to be a little cheaper than DeWitts.
Re: Anyone see that dual 11" BeCool Fan in Jegs???? (KenSny)
It does fit fine with about 1" clearance on each side.
More info on mounts and wiring from the instruction sheet: http://temp.corvetteforum.net/c3/steveg75/fanmount.jpg http://temp.corvetteforum.net/c3/steveg75/fanwire.jpg
St. Jude Donor '07
Re: Anyone see that dual 11" BeCool Fan in Jegs???? (SteveG75)
The discription say's it includes metal and plastic mounting hardware. A Haynes wiring harness is only $25.00.
Former Vendor
Apples to Apples
We are less expensive for the same product. Many people quote a price for the fans only and leave out the wiring kits, relays, thermostat, etc. Don't forget, with dual fans you need two harnesses. We sell the SPAL dual 11" fan for $248 and the complete kit is $344
www.dewitts.com/pages/productdetail.asp?ProdID=211
[Modified by Tom DeWitt, 5:37 PM 12/18/2001]
