need pic of wiper door relay valve
need pic of wiper door relay valve location
I am installing the wiper door parts and dont know were the relay valve goes. I know it is on the pass side fender but my fenders are new and there are no holes so I dont know the location so if someone could post a pic it would help. thanks John
[Modified by je68, 10:01 PM 12/13/2001]
Re: need pic of wiper door relay valve location (je68)
It goes on the metal support by where the gills are. There should be threads in the bracket for the bolts to go into. As far as the relay, it looks identicle to a headlight actuator relay. I tried using it in the place of one of mine and it must be channeled differently.
Received 1,468 Likes
Cruise-In II Veteran
Rear of right inner fender skirt. You can see it through the gill, but you have to look for it. WS washer jar is under there too for non-AC cars.
Re: need pic of wiper door relay valve location (Easy Mike)
I also have washer missing never installed. But I have all of the parts I havent thought of were it goes yet but need to now as it is next. If someone could take a pic it would help thanks.
Said it once, said it a thousand times, all C3ers need to own an AIM. You won't have to wait for a response from the forum, it will be at your fingertips.
Mark
Mark
Have an AIM and it does not show
Mark
...there are no holes...
I just checked again and the 68 AIM shows it goes on inner fender but no detail also the same for washer tank and no dimples
