does the distributor advance weights have plastic bushings around the pins??
just installing my new vacc adv canister on my distributor....
i have a recurve kit that comes with new plastic bushings....
does an hei dist use plastic bushings around the weight holes where it goes over the pins??
thanks!!
thanks!!
Re: does the distributor advance weights have plastic bushings around the pins?? (daily_driver)
No plastic bushings used on the weight pin holes in the kit I got from lars for my HEI.
Moderator
I thought the plastic bushing went over the end of the vacuum canister pin on the dist base plate to limit the amount of total vac advance. Don't think I've ever seen any bushings at the weights themselves. Probably gives you a couple different sizes in the kit....
Re: does the distributor advance weights have plastic bushings around the pins?? (MasterDave)
ok cool, ill skip em since theres none in there now and the curve is already what i want... (36 total with ~15 initial by ~2500 rpm)
i just thought the vertical play was excessive without bushings on the weights and it seems the holes are big enough that there shouldbe some bushings.......
hopefully LARS will chime in anytime now???
LARS you out there buddy??
thanks guys!
thanks guys!
doh!
i just read on this MR gasket spring set that i have that the bushings do go on the weight pins!!!
:conehead :conehead
those holes looked a bit too big :jester
my old bushings must have disintegrated or something heh
:conehead :conehead
I asked Lars this same question about a week ago. According to him they are not necessary.
David
David
Re: does the distributor advance weights have plastic bushings around the pins?? (DavidOrr)
if lars says they are not necessary, then THEY ARE NOT NECESSARY!!
thanks for clearing it up
:cheers: :cheers:
i wish i had some new pins and 106 weights now...
mine look worn.....
:cheers: :cheers:
mine look worn.....
Cruise-In I Veteran
Cruise-In II Veteran
early HEI had no bushings but later ones do because the weights wore grooves the pins. there is a after market bushing kit with a drill jig to change over to over size bushings for repair of worn pins :chevy
Re: does the distributor advance weights have plastic bushings around the pins?? (clem zahrobsky)
some have them if the holes are too big they are needed like clem said..the mrgasket set comes with different sizes to fit i have one in front of me right now...yours looks very sloppy worn out...
Re: does the distributor advance weights have plastic bushings around the pins?? (pats406nitrovette)
i went to the GM dealer today to get new pins and 106 weights becuase the holes are worn too big from where it contacts the pins....and the GM guy didnt know WTF i was talking about....
then he said he doesnt carry those items..
local auto parts stores and speedshops drew a blank also..
does anyone know where i can get replacement pins and replacement "106" weights??? the curve is setup exactly as it should be right now... so i dont want to go to some other weights.. (i do have some mr gasket curve kit weights but dont want to use them)
thanks!!
thanks!!
hey clem, you wouldnt by chance have a maker and part # for that kit wouldja??
thanx
thanx
Bushings for my '76 were/are available from NAPA. Echlin # DP112 Advance Bushing Set. About $3-4.
Re: does the distributor advance weights have plastic bushings around the pins?? (glen242)
napa!!
i havent tried them yet...(havent been there in years...)
thanks glen
thanks glen
Cruise-In I Veteran
thexon is the brand i have and they came from the auto parts
You can see the nylon bushings in this pic. They cost about $2.00.
Re: does the distributor advance weights have plastic bushings around the pins?? (paul79)
i went to NAPA auto parts today and THOSE GUYS KICK SOME ****!!!!!!!!!!
before that i had gone to -discount auto -western auto- 1stop -gm dealer and none of those fools had distributor pins and 106 weights or bushings..
NAPA auto parts carries 106 weights, the pins, and the bushings!!!!
If you need advance weight bushings I have them. Contact me at automan_1954@hotmail.com and let me know how many pairs of bushings you would like. Bushings are $5 a pair with free shipping to the continental United States.
heh this is odd... all my MSD pro billets don't use the bushings either, maybe because they are race oriented, but you'd think they'd use bronze or some kind... learn something new everyday I guess
