Urethane bumper cover paint prep
Old 12-13-2001, 12:51 PM
UKPaul
UKPaul's Avatar
Default Urethane bumper cover paint prep
I've had an offer to spray my bumper covers (you know, the UGLY ones!) "for a good price" as long as I do the prep myself.
Does prep for painting just involve rubbing it down to remove loose/flaking/oxidised paint or does it mean that I've got to remove all of the paint?
TIA
Paul
Old 12-13-2001, 01:56 PM
Paul 75 L82
Paul 75 L82's Avatar
Default Re: Urethane bumper cover paint prep (UKPaul)
I'll tell you what I did. I just wet sanded the bumper and sprayed on a coat of PPG DP50 sealer and painted over that.
Old 12-13-2001, 02:09 PM
79MakoL82
79MakoL82's Avatar
WOW. You must have read my mind. I've become REALLY tired of looking at the chips and paint cracks in my "ugly" rubber bumper (mine truly is ugly right now), and on my way into the office from lunch was wondering the same thing. How do you prep the rubber bumpers?
Old 12-13-2001, 02:12 PM
lars
Support Corvetteforum!
lars's Avatar
Received 4,926 Likes on 1,931 Posts
Default Re: Urethane bumper cover paint prep (79MakoL82)
Here's how to prep 'em. This is from a paper I did on this a while back. If you'd like a clean, properly-formatted copy of this in MS Word format, drop me an e-mail, and I'll send it to you:
Rubber Bumper Repair Basics
by Lars Grimsrud & Butch Powers
SVE Automotive Restoration
Musclecar, Collector & Exotic Auto Repair & Restoration
Broomfield, CO
Rev. A 10-1-01
This tech paper will discuss basic repairs to the rubber & plastic bumper facias typically used by GM and other automakers. These rubberized components have been around since the GTO "Endura" bumpers of 1968. The parts often erode, tear, or get gouged, but can be easily repaired to like-new condition if the correct processes and materials are used. Different auto body professionals have different preferences as to how to do things, and I may get some disagreement on the specifics of this article. This article will provide you with a group of products and materials, and my personal technique, for accomplishing first-class results.
General Info
The rubber bumper facias used on Corvette front and rear bumpers actually hold up pretty good. The most common problem is rapid deterioration of the factory-applied clearcoat on these components. Usually, the parts only need to be wet-sanded, properly prepped, and repainted with the correct materials. In cases where the parts are torn or damaged, the repairs are very simple, and produce excellent results. The most difficult and time-consuming part of the job will be removal of the parts from the car: it is very difficult to get excellent results without removing the bumpers and disassembling them down to their component part level, since the tail light lenses on a C4 cannot be removed from the outside of the vehicle (very easily). Masking the parts off without removing them does not produce acceptable results.
Supplies, Fillers, Primer & Paint
In addition to some of the basic tools and supplies outlined in my "Corvette Body & Paint Repair Basics" article, you will need the following "stuff:"
1 qt Transtar Hydroflex Waterborne Acrylic Primer, P/N 1234
1 kit SEM Rigid Sem-Weld II, P/N 39508
1 qt DBU Basecoat in the correct color
1 qt DRR1170 basecoat activated reducer
1 qt Concept 2021 clearcoat
1 pt DCX61 hardener
1 qt DT870 reducer
1 pt DX369 Flex Additive
Econo-grade lacquer thinner for cleanup
150 grit sandpaper
400 grit wet-or-dry sandpaper
600 grit wet-or-dry sandpaper
Masking tape
Paint strainer
Rubber sanding block
Paint gun & compressor
Technique
Gouged, torn & damaged areas:
NOTE: Before doing any work on any parts, be sure to degrease them well with a good wax & grease remover. If silicone products have been used on the car (like Armour-All on the tires), use a good silicone remover and wipe the parts down well. If you don't do this, you will grind silicone and contaminants into the rubber parts during the sanding process, and your paint will "fisheye" like crazy.
1. Tears and cracks in the facia should first be "stop drilled:" at the very end of the tear or crack, drill an 1/8"-or-so diameter hole all they way through the part.. This will relieve the stress at the end of the crack and prevent it from propagating any further.
2. Using a grinding wheel, cutoff wheel, Dremel Tool, or other suitable equipment, prepare the crack, tear or gouge by 'V-Grooving" the damaged area and removing all loose material. If the material is thick enough, V-groove both the front and the back side. If not, at least V-groove the front (top) side. It's important that the filler material you'll be applying has a good, fresh groove to be squeezed into in order to promote good bonding adhesion.
3. Fabricate a backup strip. If the tear or crack is in a particularly flimsy area, cut a thin piece of metal or plastic to bond onto the back side of the repair to stiffen it up.
4. Mix up a little bit of the Sem-Weld II. Apply it to the damaged area, and bond your back-up strip to the back of the repair using the SEM (if needed). Squeeze the SEM really good into the damaged area.
5. Once cured, sand and shape the filled area with your 150 grit. Apply a second coat of SEM if needed, and re-sand.
Part is repaired and ready for refinishing!
General Refinishing
Most of the rubber facias are not damaged, and are only oxidized and/or slightly crazed (like their owners). Here are the steps to refinish these parts, as well as to finish off the parts that have been repaired following the repair procedure above:
1. Wet sand the entire part with 400 grit and a sanding block to remove all oxidized and loose paint. Sand all crazing smooth and blend out any chips in the paint with the surrounding areas. Sand the repaired areas described above with the 400. Dry the parts well.
2. Shoot 2 coats of the Transtar Hydroflex Waterborne Acrylic Primer onto the parts. This thick, black, rubbery primer does not need to be reduced, and will clean up with water.
3. Let the parts cure overnight. If you attempt to sand the parts any sooner (in spite of what it says on the can), the primer will ball up and peel off the parts.
4. Wet sand the parts with 400 grit wet on your rubber sanding block until smooth. If all of the defects are completely gone, switch to 600 grit, and sand it again. If there are still a few little imperfections, dry the parts off well and lay another coat of the Hydroflex onto the parts. Wait a day and finish the parts off with the 600 grit wet.
5. The parts can now be topcoated with your basecoat color, mixed 1:1.5 with the activator.
6. After 30 minutes, mix your 2021 clearcoat, but mix it 4 parts 2021 to 1 part DT reducer to 1 parts DCX hardener to 1 part DX369 flex additive. This will keep your parts from cracking and crazing. Give the parts a dry tack-coat, and then follow with a couple of nice, wet coats.
7. If desired, the parts can be "color-sanded" after a day with 1500 grit and buffed out as I described in my Paint Basics article. If you leave them in their as-painted condition, they will look very much like the new, factory finish.
Other Notes
The only problem I have run into during this process has been when shooting some of the more translucent basecoat colors: metallic red, for some reason, is fairly translucent. The underlaying black Hydroflex primer will make the translucent colors look darker than they should, unless you put a LOT of coats of basecoat on the parts. Generally, heavy basecoat buildup will degrade the longevity of your paint job, so this is not desireable. To avoid this when working with the more translucent colors, I have been giving the primed rubber parts a light coat of white basecoat before applying the actual basecoat color. You can also shoot a light coat of your grey or white DP epoxy primer onto the parts to achieve the same effect. This will assure you of a proper color match with no bleed-through of the dark base surface.
Old 12-13-2001, 02:38 PM
Chris Fowler
Chris Fowler's Avatar
Cruise-In IV Veteran
St. Jude Donor '03-'10
Default Re: Urethane bumper cover paint prep (lars)
I'm guessing if the rubber bumpers are warping they just need to be replaced...
Mine are nice and wavy... :(
Old 12-13-2001, 02:41 PM
lars
lars's Avatar
Default Re: Urethane bumper cover paint prep (Chris Fowler '80)
Yeah, there's no good fix for the wavy bumper problem. Either replace 'em or sand as smooth as you can, paint 'em, and make 'em nice and shiney - they'll still look good if they sparkle...
Old 12-14-2001, 01:46 AM
Chris Fowler
My front bumper is probably servicable.
The tail is really wavy. It's probably going to have to go away when I get around to painting...
Old 12-14-2001, 08:47 AM
UKPaul
UKPaul's Avatar
Thanks for the replies everybody.
Lars: Good document - cheers, just what I needed. My bumper isn't too wavy but the paint is bad. Looks like I'll be spending Xmas sanding bumper covers :)
:cheers:
Paul
To Urethane bumper cover paint prep
Quick Reply: Urethane bumper cover paint prep
