State vehicle inspection question....Yes, I have an inspection question
Took my 97 lexus to the ridiculous NJ super duper 2 yr inspection yesterday. Wasnt too bad, but today I was thinking about the whole stupid process: They check your gas cap (!!), run you car on a dyno (too bad they cant give you the horsepower rating), and stick a probe up your car's butt and give you a computer printout. I guess they also check the lights, and that alarming run up to the car in front must have been the brake test. (Gee...if your brakes fail the test the moron rearends the car in front of you!!).
But today I suddenly realized that they did not pop the hood and they didnt take a look under the car. If you take in a vette, or an older car, do they check for underhood mods/equipment? and check your exhaust system for cats... or mufflers for that matter??? just wondering... MJ
[Modified by MNJack, 11:45 PM 12/11/2001]
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Re: State vehicle inspection question....Yes, I have an inspection question (MNJack)
Not sure about your state but Utah does both visual and sniffer emission test. Never had to get the vette tested though since I was from Indiana. They also do the safety test. At the auto hobby shop on base (Air Force), they had a machine that tested the brakes in a similar way. The guy would drive the car onto what looked like a drive on lift and then slam on the brakes. The machine could tell how much pressure was being applied to each wheel and if they weren't within a certain percentage of each other, you failed. They also tested the parking brake that way. The thing that scared me is they were driving straight at their computer machine. Hmm, who would be responsible to pay if the brakes failed? You, because it was your car? or the guy driving?
hey MNJack....ive been through 3 times in the past year with the vette. They opened the hood twice and didnt once.
I think they might have opened because of curiousity, but ive seen them open hoods of other cars as well. But i dont think they care whats under there, most likely making sure its not smoking. Because my motor looks nothing like original since there is no AIR, or cats, and have chambered mufflers, which they noticed all of these, but didnt fail because they werent there.
To make it simple, as far as i know, they dont care whats there as long as you pass the emissions test and safety.
Chris
Chris
HAHA, that gas cap thingy is a typical example of a federal law whichy will never go away, so we all spend a zillion hours checking gas caps...for restrictor plates that don't allow a larger size filler tube to be inserted in the neck....the size was reduced to differentiate between leaded and unleaded gas...and so....any car with a restrictor plate has to have it intact...so as if anyone could ever even FIND leaded gas anymore without a whole lot of hassle....dumb bastards....
now a daze....that 'old' filler tube large size is used for diesel...so we can stink up the atmosphere even more...!!!!
GENE
GENE
Hmmm...not sure.
But you'll be happy to know that if you move to Lousyana your car only has to be able to roll...even if it's towed...to get an inspection sticker!!!:lol: :lol:
You should see the crap driving the roads around here :eek: :eek:
Re: State vehicle inspection question....Yes, I have an inspection question (mrvette)
GENE
GENE
What worries me is that the inspectors don't know much about cars. I've had inspectors tell me my vette won't pass due to an open element aircleaner. I asked why the air cleaner wouldn't pass and they said it has to have the thermostatic flap to suck hot air when the engine is cold. That's great, except the '71 Corvette never had a thermostatic aircleaner!
Re: State vehicle inspection question....Yes, I have an inspection question (zwede)
Hey Mark,
I was just thru about 2 weeks ago. No dynos for us, they check emissions at idle. Also looked under the hood, but they have absolutely no idea what they're looking at.
:cheers:
-Tom
:cheers:
-Tom
Re: State vehicle inspection question....Yes, I have an inspection question (Chris A)
before some year in NY emission equipment doesn't matter.
I will say that I had my car for about 3 years when an inspection discovered a compression fitting on my rear brake line. So for once it was worth it. This was not a chain store and another reason not to use them.- chain stores.
Re: State vehicle inspection question....Yes, I have an inspection question (Techno)
I only need to get a safety inspection on my Vette. The garage that I bring it to doesn't check anything on my Vette. Not even the lights. He just scrapes off the sticker and puts on a new one. :)
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I had mine inspected at my local gas station (don't trust the state). They dyno'd it and in doing that they input the car's year. If you pass emissions they really don't care if you have a cat or any other mod as long as you pass the sniff test (don't think you could pass w/o cat).
In pa. state insp. is a pain,the county i live in we have no ems. they inspect
tires,tail pipe,muffler,horn,pull front & rear brakes,wipers,and every thing else,
don't get cought with bubble lights and no back up lights,.....jbh :eek:
