Hey '69 Owners...
Hey '69 Owners...
Could some please tell me the correct color for the word 'BRIGHT' on the speedo when your highbeams go on?
The speedo I pulled out of the car had a red warning, the replacement I just got has a bluish warning.
Easy enough to swap the lens while the gauge is apart, I just want to make sure I put the correct color in.
Thanks... :cheers:
-Tom
Thanks... :cheers:
-Tom
Re: Hey '69 Owners... (427_Roadster)
Mine is red I think....been a while since I took the car apart...no battery in it at the moment
AC
AC
Location: Godspeed Mikey Hogsmak Invitational Spring Skyline Drive Corvette Cruise
Cruise-In I Veteran
Cruise-In II Veteran
I have the original in my 69 but I can't check till tomorrow for you, I do think it's red though :chevy
Re: Hey '69 Owners... (Flareside)
Woops, mine may be wrong too! I can't believe I actually found this thread from 18 months ago. Check it out: http://forums.corvetteforum.com/zerothread?id=25185
-Joe
-Joe
I'll have to check my early '70 and see if that holds true... Regardless, you're safe going with the red warning for your '69
Regards,
Re: Hey '69 Owners... (Rowdy Rat)
Mine is Red - I cannot inform you as to whether correct or not. I would assume it indeed is correct.
Re: Hey '69 Owners... (kaiserbud)
Thanks for all the replies...
Looks like red it is - good thing too, now I don't have to also rip out the tach for a matching 'BRAKE' light!
:cheers:
-Tom
:cheers:
-Tom
I have a car with a blue light and a car with a red light, both I think are original (haven't check the other car). The blue one was early in the production run, number 3 or 4 thousand.
[Modified by 69Roadster, 10:07 PM 12/11/2001]
Red Light buddy just like your absolutely fantastic Vette. Man am I jealous. You have to post some more pics of that baby sometime.
Mine is red. So is the BRAKE light fwiw.
Dave
Dave
