Build Sheets
Re: Build Sheets (cynthia)
For a window sticker reproduction, try here:
http://www.window-sticker.com/
Received 1,468 Likes
Cruise-In II Veteran
None of the records from the St. Louis facility are available. Your best hope would be to locate a copy of your Corvette Build Order somewhere in the car. There may or may not be a copy glued to the top of the fuel tank. Copies of build orders have been found in the wiring tucked behind the speedo/tacho, behind the kick panels, in the wiring above the heater box, tucked into the springs beneath seats, and beneath the carpet in the rear storage area. If possible, you could contact prior owners to determine whether they might have some of the original documentation which came with the car. Good hunting.
As per Neo Fender's suggestion, please see attached pic of a window sticker for my 1979. http://albums.photopoint.com/j/Album...a=13454990&f=0
