Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior How-Tos
- Corvette: How to Remove Visor Warning Label
Step by step instructions for do-it-yourselfers...
[Z06] Definitive Visor Warning Label Removal
Forum members, I know there have been several threads on this, but after reading all of them, and now removing 9 warning labels from 4 cars (my wife's Durango had two on the driver's visor) I can now give definitive guidance. I have done both, in-car removal (the Z06, because I couldn't figure out how to remove the visors without damage) and in the house after removal from the car. Clearly, it is easier if you can remove the visors, in all my other cars there were 2 or 3 screws and a wire connector per visor and doing the job on the kitchen counter was much easier, but I did the Z06 last in the car with the same results. Here's the procedure:
Tools: hair dryer, very sharp small knife (I used a Swiss Army knife), Goo Gone, clean cotton towel, small stiff brush (I used a plastic fingernail brush).
Steps:
1. heat up the label with the hair dryer. do this carefully because the polyester fabric can burn/melt, the hotter the better on the label though because more of the glue comes off with the label the hotter it is. This took 3-5 minutes to heat up the label sufficiently, with the hair dryer about 1 inch from the label.
2. with the knife, scrape up one of the corners carefully, while running the dryer on the label, if it is hot enough, the corner should come up a little bit. Grip the corner with your fingers and continue slowly pulling the label away from the visor, again while keeping the hair dryer aimed at the label.
3. the label should pull away fairly easily, but keep the dryer aimed at the portion of the label that is still attached to the visor. Once it's off it's off.
4. now, what you will see is a slight indentation in the fabric and a very thin film/sheen of glue in the outline of where the label had been.
5. dab on a liberal amount of the Goo Gone in the indentation. don't use enough to drip, but paint it on well.
6. carefully, heat up the area where the Goo Gone is with the hair dryer. this should be quite warm, but not too hot.
7. wipe away the Goo Gone and glue with the towel, scrub the visor with the towel well, pulling the towel back and forth, up and down. I found that it should only take one application, but if you still have a bit of glue, do it lightly again.
8. Last, heat up the visor once more, and take your brush and brush the whole visor up and down, back and forth and in circular motions. This should raise all the fibers such that the indentation disappears.
9. You should be done. Leave the windows open so the Goo Gone smell will get ventilated out.
This took about 10 minutes per label, it wasn't messy, difficult or dangerous to the visor or car interior. It looks so much better, and the visor looks completely consistent, the area where the labels were are completely invisible. Do it!
Good luck--
Ed
Steps:
Good luck--
Ed
z06clif (11-03-2015)
Been There Ruined that.......
Ed, thats great your having success removing the stickers on a Z06. I tried removing them and ruined both visors and the rear view mirror with the product goofoff and will never attempt this again. If you want to try this I would be very very careful with goofoff as it will damage some plastics(says on the product label). Googone is a much better bet if you attempt it. Greg
--Ed
Greg, your original post is what motivated me to do the research and get this done without the unfortunate results that you ended up with. Goo Gone is not a strong solvent like Goof Off, so it did the job without the risk of damage. Additionally, the heat of the hair dryer makes a huge difference. Once hot, the label just peels right off. I'm sorry you had the trouble you did, but at least one reader (me) took your comments to heart and learned from your experience.
--Ed
--Ed
Thanks for the post, Ed! There was a similar post on a Porsche board that motivated me to successfully remove the stickers from my 911. I will attack the driver's side Vette visor after work tomorrow.
BTW, per the shop manual, by design you cannot remove the visor without damaging the "inner bezel". The manual states that the inner bezel must be replaced. Maybe GM wanted to make lable removal a bit harder?
We would like to either get rid of ours or cover them up.
Thanks in advance!
http://forums.corvetteforum.com/show...t=visor+decals
St. Jude Donor '06-'07
--Ed
--Ed
I did it successfully on 4 cars (8 visors)
I'm sorry this didn't work for you, and quite surprised, if followed exactly. It may be a heat-based adhesive, true, but I used the hair dryer to warm up the label until it was quite hot, and when the label was removed, there was only a very, very faint "ghost" as you call it, which was primarily the indentation of the fabric fibers where the label had been. Again heating up this spot and applying a bit of Goo Gone and brushing the area back and forth and up and down completely eliminated the indentation and any glue residue. It is completely invisible on all the visors I did. I think the heat and the brush do the the trick.
Ed - in this step - when you mentioned 'paint it on' - is that taking a small clean brush and literally painting the Goo Gone on - or is it taking a terry towel (or similar) and applying it lightly?
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
I had no luck with the vinyl decals over the warning labels... go from a cool garage to summer heat and they curl right up at the edges...
Played around with it and figured it out.
Technique worked flawlessly on my 09 Z - a little more scrubbing with the fingernail brush and heating to get the fibers back in place than I thought - but the end results was great - no ghosts, glue, or damage to the visor.
Gloves helped a bit as that hairdryer gets damn hot!
Car smells like a big orange due to the Goo Gone - hopefully that will ventilate out
Oh Oh...now someone is going to take the next step and remove the do not remove tabs from pillows and furniture.....you could all end up in prison .........OK I'm kidding Great post and good info here....thanks
Andy
