Clock replacement
Clock replacement
I know that this topic has been covered many times sorry for asking again but this forum seems to have the answers for most everything. I have a 69 coupe and want to change my non working original clock to quartz. I'm probably just going to jbuy a replacement. Could someone give me the step by step process on removing it from the center cluster and what to expect or direct me to a good publication about the procedure etc?. Also once the cluster is out I thought about repainting it( has some wear around the seatbelt button). What do you guys recommend? Thanks in advance for any input.
Re: Clock replacement (marks)
Marks,
If you would like, I can e-mail you the procedure for clock removal and relpacement. I have it on file in my computer. Let me know.
Ben :smash:
Ben :smash:
Re: Clock replacement (7vette2)
Ben,
I would appriciate that. I was playing around with the cluster and seemed to begin to figure things out until i ran into those two bolts and nuts that are connected under the radio. How in god's earth do you get to those?. Thanks for the reply.
Mark
Mark
Ben,
If you get a chance, could you email the file to me as well? I'm about to undertake the great clock caper myself.
Thank you,
Jeff
jeffnles1@msn.com
Thank you,
Jeff
jeffnles1@msn.com
Ben,
Mark
Mark
Word of caution: Disconnect your negative battery cable first. Also, have a rag handy to rest the threaded studs against after you pull the cluster panel away from the dash.
Good luck!
This is one of those great "while you're at it" projects. Once you have the cluster out is a good time to replace all the light bulbs. You might also decide to replace to clear lens for the gauges - it's all one piece, easy to replace while you've got it apart, and I think it was less than $10. You'd be amazed at how scratched up these things get after 30 years!
Take your time, walk away for a little while if you start losing your patience....it's tedious stuff, but it'll look great when you're done.
Ben,
Mark
Mark
John
[Modified by theandies, 9:52 AM 12/9/2001]
