Fun Time - How Fast Will My Rebuilt Vette Go!?!
I don't need no stinkin' G-Tech... I got all the help on the forum right here!
Here's the drill...
383 CI
stock qjet
stock exhaust (2 into 1 with cc)
200 4R with fourth gear at 0.67 ratio
3.08 rear gear
Stock weight ('76)
Whats my rebuilt car capable of...?
Here's the drill...
383 CI
stock qjet
3.08 rear gear
Stock weight ('76)
Re: Fun Time - How Fast Will My Rebuilt Vette Go!?! (Carl in LA)
You forgot to mention how many hp/torque your engine puts out....
oh, and how much does your car weigh?? Then I will tell you! :)
oops, I forgot to READ.... a common affliction here.. you said, "stock weight" MJ
[Modified by MNJack, 12:08 AM 12/8/2001]
Re: Fun Time - How Fast Will My Rebuilt Vette Go!?! (MNJack)
Don't know yet... I get the engine back tomorrow and may take several weeks to reinstall... then a few more weeks to tune and then off to the dyno.
The engine rebuilder spoke in terms of 350 to 390 hp depending on whether I had the small valve (?) or large valve heads (?). He never mentiontioned anything about the heads when he called. He did mention that he had to use a cam with "less" overlap to allow the engine to pass smog here in the basin.
Everything else in my life an analyze to death... this time I just told him to build it!
That kind of HP sounds great....just a shame you have to force it thru a 2-Y pipe system. Will a Hi-Flow Converter pass specs? If so, I think it would be an awfully good investment. Made a very nice gain in my stock L-48 by removing my Y-pipes and going to true duals. :yesnod: :seeya :flag
