Wheel hop?
Wheel hop?
I am in the process of addressing suspension issues, and was wondering if anyone else has a wheel hop problem. I have the fiberglass rear spring, and it seems to hop really badly, especially in the rain.
This isn't a huge problem, since it only happens when the wheels are spinning :yesnod: , but it is rather annoying. Any ideas? :confused:
Re: Wheel hop? (inqbus383)
I also have a 79 and have never had wheel hop. but years ago I went with 550 front springs poly everything and 1 1/8 bar with adjustable ends. In the rear i went all poly HD trailing arms 320 or 340 mono spring Smart struts 3/4 rear with adjustable ends
I felt that the mono spring caused way to much rear squat. I also noticed from your pictures that your front end really rises. I changed to a 420 lbs steel spring. I have always been impressed with Trans-am race cars. If your watch them go around a track the front end never changes more than three inches or so from wide open throttle banging gears to stompng on the front brakes at 175 mph to make a 30 mph turn.
So I attempted to do the same thing with light weight body parts and gutted under the hood with some of the biggest springs made. My car slides before I have body roll. I compete in BSP 315/35/17 rears 265/17 fronts
It's a common problem with the composite springs, it's not the fault of the spring but the shocks! The composite has less friction than steel so you'll need a shock that can control the bouncing and/or wheel hop. I've used the Bilstein (sport) shocks and a buddy of mine used the special composite valved shocks from VBP. They both work very well although the Bilsteins are better. :seeya
Re: Wheel hop? (Brian Madderom)
I also thought that it might be the spring. But his profile has some good shock listed. I'm just guessing. If you had older components with some slop and give combined with a lighter inch pound fiber spring. Wouldn't it allow enough movement that no matter what shock you put on, wheel hop would occur?
Thanks guys. I checked, and i seem to have the stock black AC delco shocks. Guess i will get some blisteins! :yesnod:
The Blisteins are on my wish list, this is a great excuse to buy them! :smash: :jester
[Modified by inqbus383, 11:09 PM 12/7/2001]
