New clutch recommendations?
I'm about to purchase new clutch for my '68. I've never used an aftermarket clutch, so I don't know much about them. Should I stay with GM parts or get a Hays, Centerforce, etc. Engine is a 427/390 (with mods planned in the near future), and transmission will be a Richmond 5-speed that requires a 26 spline input.
What size flywheel and clutch does my car have stock, and how many teeth are on the flywheel?
Thanks!
Joe
Thanks!
Joe
Re: New clutch recommendations? (Flareside)
I'm pretty sure that all big blocks came with the 11" clutch and 14", 168 tooth flywheel.
I'm running a McLeod dual performance clutch and PP, and I'm happy with it so far (about 350 mi).
Flareside, Chris is right about clutch size, although you should check the # on the bellhousing to be sure. I can research what # is for 11" and which is for 10&1/2"
I have same engine as you in a '69. I went with a GM heavy duty clutch from Sallee Chevrolet.I have no complaints with it and it is abused regularly. Pedal effort not bad at all.
Good Luck, Mark :flag :chevy
Re: New clutch recommendations? (marky mark)
I just installed a Centerforce DUal Friction based on the recommendations of Forum members. This is a great clutch. My 427 turns 500 lbs. ft. of torque at 2700 rpm and over 450 hp at 5500 rpm and the clutch grabs great, even when I open the secondaries in first gear. I highly recommend it.
I think the pedal effort is about the same as what was in my car (probably not original), but it was also about 9 mo between when I put in the new clutch and the other stuff.
You bellhousing should end in 621
I have a freind that is a SPEC dealer they are a real performance style type clutch they are high quality so if you would like more info on these clutches let me know and ill give you his E-MAIL ADDRESS :cheers: :cheers:
