CARPET INSTALLATION - Check out the results!
http://temp.corvetteforum.net/c3/78redshark
Let me know what you think! :cheers:
[Modified by 78RedShark, 6:29 PM 12/6/2001]
[Modified by 78RedShark, 6:30 PM 12/6/2001]
Received 1,468 Likes
Cruise-In II Veteran
Re: CARPET INSTALLATION - Check out the results! (78RedShark)
Looks like a nice job.
Re: CARPET INSTALLATION - Check out the results! (scottw)
Looks pretty good for vendor carpet.....All the stuff I saw from the vendors just looked too cheap...but urs looks good....Are those the original seats..i thought the 78's had those cool molded two piece seats
[Modified by Alwyn678, 1:41 PM 12/6/2001]
Re: CARPET INSTALLATION - Check out the results! (Alwyn678)
Alwyn, those were the original seats (if you can believe it)...the two-piece ones I believe were just for the Pace Car in 1978, then became optional for all models in 1979.
Nice looking interior. Can I have the cube walls you removed :lol: :lol:
Seriously, did you put down a heat barrier under the carpet? You'll be glad if you did. The job wasn't as hard as you thought huh? The hardest part I found was trimming only the padding. It was attached to the carpet, and had to be removed in spots for me to get the proper thickness under the shoulder harness retractor, and seat rails. The factory bolts were too short to reach through both carpet and pad. Nice job.... Good Luck :D :D :D
Re: CARPET INSTALLATION - Check out the results! (Silvr77)
Yeah, silver...I had the same issues with the jute padding...especially under the seat rails...but where there's a will...
The cubicles are yours...actually flip a coin with SUperFast 80 :lol:
Thanks!
Thanks!
Hey Red,
Your 78 looks beautiful! I have the same carpet kit (black) sitting in the garage waiting for me to get off my big A-- and get busy.
Good to see the quality from Corvette Central... and the time you spent on it really paid off.
