Does anyone want to use Wilwood Dynalite II calipers?
C6 the C5 of tomorrow
Because now you can!
Yes there are more expensive calipers out there
Yes, there are those cool 6 piston caliper designs
Yes they still use the stock rotor
There have been many discussions on calipers and rotors. But the bottom line is these are dang good calipers at a really good price and the Vette's 11 3/4" rotor is plenty big for 99% of the people out there
Yes they are a HECK of a lot better than the stock caliper!
* Lighter
* Less Leak prone
* Less suceptable to air pumping due to rotor runout
* Better heat rejection
These calipers Will NOT improve your stopping distance, that is determined by your brake pads and your tires. If you can lock the front brakes there is no more the caliper can do...
Here's the Ad..
http://forums.corvetteforum.com/zerothread?id=195568
[Modified by 427V8, 8:35 AM 12/6/2001]
* Lighter
* Less Leak prone
Here's the Ad..
