Replacing air adjustable rear shocks
Old 12-06-2001, 12:03 AM
TFeld78
TFeld78's Avatar
Default Replacing air adjustable rear shocks
Haven't seen anything on the procedure on replacing air adjustable shocks.
Should the air pressure be released before removing the mounting bolts
or after? The answer will probably be pretty obvious when I hear it :D
Thanks.
Old 12-06-2001, 12:06 AM
PatsLs1vette
PatsLs1vette's Avatar
Default Re: Replacing air adjustable rear shocks (TFeld78)
yes release the air out first ..by the way how do they ride with air shocks on it is it a hard ride?
Old 12-06-2001, 12:12 AM
TFeld78
TFeld78's Avatar
Default Re: Replacing air adjustable rear shocks (pats406nitrovette)
I'm not really sure, I slowly lose pressure and have to "re-inflate" them
every so often. In addition, the rear spring is fairly flat. My plan over the next month or two is to replace the rear shocks and the spring.
The ride is not bad, all things considered. I personally like the "feel" of my 78 compared to my wife's 82 with a fiberglass spring.
To Replacing air adjustable rear shocks
Quick Reply: Replacing air adjustable rear shocks
