What type of oils to use
I just got my 74 and need to know what kind of oils and lubes you guys reccomend.
Oil
rear end
transmission
brake, ect.
Oil
rear end
transmission
brake, ect.
Re: What type of oils to use (scottw)
I'm not too concerned about engine wear because i'm usually in there every couple of years anyway. It takes no effort to but bearings in. I just use off the shelf Quaker State 10W30. The rearend get's 75-90 synthetic with a bottle of GM posi additive. The trannys also gets Quaker State ATF, but I change the fluid often enough to keep the grungies out.
