easy way to install coil springs
I know this way of doing this has been talked about before.But
I don't remember seeing pictures. I had to do this today so for once I took a few pics so you guys could see how easy this is. I used a 5/8 threaded rod an old buffing pad so I didn't scratch the paint and a steel plate on the control arm side. Run the rod through the shock mounting hole and thats it. This works the same with the body on or not. No need for anything else. Brian G.[IMG][/IMG][IMG][/IMG][IMG][/IMG]
I assume you put a steel plate on top of the shock mounting plate also?
BTW, how many quarts of primer and paint did it take to do your frame? I'm going to use the Eastwood brand.
Thanks again!!!
Man aworks talk about perfect timing. I'm just about to blast and paint my frame and I was just telling my wife last night that I didn't know how to compress the coil spring without renting or buying a spring compressor (or whatever they're called). This REALLY helped me out a bunch!!!
Thanks again!!!
Thanks again!!!
Last weekend I put the springs in a 65 BB car I am restoring. Since I did not have the engine installed, there was no weight in the front end to assist me. I actually found a way to do it that worked well. I raised the lower A arm to hold the spring in position against its perch in the frame. I disconnected the upper A arm, attched the ball joint to the spindle and moved the upper A arm back into position and reinsatlled the bolts and shims. Now I have the rivets in the center hub of the front rotors to contend with.
Brian didn't mention it, but if you notice the red on the threaded rod, a little grease makes it work much easier with stiff springs.
It is much safer than most spring compressors since the spring cannot escape to hit anything.
