Removed Spare should I reinstall Carrier...
Does it serve any function other than carrying the spare or does it prevent wind from pocketing in there? Because I'm feeling kinda of lazy about reinstalling it if its not necessary.:confused:
Thanks
Thanks
Re: Removed Spare should I reinstall Carrier... (IT STINGS)
It was designed to provide a safety measure for rear-end collision, when the spare tire is in the tub. Also, it just looks better with the tub in place, much more "finished" look, in my opinion.
Shannon
Shannon
I've had mine off for a few weeks now. I haven't noticed any ill effects. Of course, I'm still not sure about the safety issue, but if you don't have the spare in there, I don't think the tub would offer much collision protection.
As far as aerodynamics, I haven't noticed anything negative. I'm thinking my gas mileage is up a little from the reduced weight, but I can't tell on two tanks yet.
I was going to try to put a piece of sheet metal to cover the underside of the gas tank & the rest of the area to keep road grit from getting up there, but some leave the top side of the tub up there.
I'm currently driving without the carrier, but I fixed it (had a big hole) and will reinstall it, even though I don't think it's worth carrying my spare:
:jester
-Pedro
leave it off >>>> dead wieght , dont need it ..... wieght off = more performance.....took off spare & carrier assy, when I put on new fuel tank a few yeares ago...in combination with mono rear composite spring , mini starter no p/s no p/b & alum heads my 66 convert 427 wieghs in at 3080 LBS with 1/2 half of gas ..without me in it....eventually will put on alum water pump when the cast iron one gives out & my Vettes diet will be over...if I could only take wieght off that easy... :yesnod: anyways worked for me.. :seeya :flag
