How do you install new air dam foam?
The foam air dam on each side of my radiator is cracked and brittle. I bought replacements, but the original dam appears to have a big rivet attaching it to the front crossmember. I have a 77 L48. How have you guys installed new air dam foam?
Platinum Supporting Dealership
Re: How do you install new air dam foam? (virtue4u)
This is from my 78 manual. http://vettefinders.com/rhys/pics/in...=slideshow&e=7
Re: How do you install new air dam foam? (Rhys)
Thanks, Rhys. My 77 AIM has similar pictures, but the pictures do not show a metal stud or rivet holding the air dam in place. I don't see it in my AIM or your pictures. I don't mind tearing the old dam up to get a closer examination of the rivet, but I thought that I better consult the forum before I start ripping into something. Anyone else have experience replacing the air dam?
Mine does have a metal-like pin that holds the two rectangular pieces in place. In my new radiator support though, only one hole was big enough.
on my 75 all i had to do was pull the bracket that holds the... jeeze i cant remeber the name, its the black plastic thing that helps funnel the air through the radiator... anyone know what this is called?
Cruise-In VII Veteran
St. Jude Donor '07
Re: How do you install new air dam foam? (ZD75blue)
You need to order new clips to install the foam. I also took the crappy double stick tape off the foam and used a thin film of black RTV sealant to hold the foam in place. Worked great.
