How to Make A Fuel Line???
I'm getting ready to put the ZZ383 in my 66.. I would like to make some nice fuel lines... I see the fuel line and fittings in Summit and Jegs. Is there a tool to get the fittings seated after the lines are cut.
Basically can someone tell me how to make that fuel line and what tools to buy...
When I buy a pre-made one it generally seems to be to long or to short... Besides at 62 I still feel I can still learn new tricks!
Thanks a bunch...
Capt Roy
If it doesn't work, read the instructions. If it still doesn't work, follow them!
Thanks a bunch...
Capt Roy
1960 (09-20-2022)
If they are like brake lines you'll need a way to bend the tubing and a single/double flaring tool to make the ends correctly:
http://www.eastwoodco.com/shopping/p...flaring%2Ctool
I use a tubing bender but some people fill the lines with fine sand (or they even make a compound to use for this) so they can make sharp bends.
You should practice both skills, bending and flaring, on scrap before you do it for real.
1960 (09-20-2022)
Why not look at a similar stock setup and use those lines. Lots of stuff in catalogs...
Or if you want to "roll your own" start with stiff wire to get the approx shape, then commence bending!
Your fuel line is either 3/8 or 5/16 ths. depending on the HP . The tools sre the double flaring tools, tubing cutter and some tubing benders. The best 'benders' are made by "Weatherhead or Imperial". Not cheap but THE correct tool. Anything less is a waste of money. Available at tool houses or even Plumbing supply houses. I go from 3/16 to 1/2 inch. If you can, buy these sizes. 3/16, 1/4, 5/16, and 3/8. These cover all of the Vettes lines. Your friends will love you.
'fdreanos' suggestion of some practice lines should help.
However the flaring tool is not cheap... I found it the cheapest at $275 but it seems it will be worth it... Here is the first link I found...
http://www.bizrate.com/automotiverep...121092026.html
Dave
I made mine with mostly AN fittings and flares using 3/8 brake/fuel line.
If you need any "special" fittings, here is the place to go:
http://www.performanceplumbing.com/
Note that tern plated (standard plated) brake line should polish up using standard metal polish to an "almost" SS look.
Plasticman
Plasticman
Received 6,519 Likes
C2 of Year Finalist (track prepared) 2019
Jim
I make 45 degree double flares and bend lines with my Snap On tubing kit and a standard tube bender. Never had a problem, so I'm not sure you need a $275 tool for this task.
I'm with you - I added a dual reservoir, power brake M/C unit onto my '66 Mustang with a lot of bending and flaring and had to redo maybe one flair - all with a set of tools I got for under $40 (and I can't find my darn dble flaring tool now ?!). $275 is fine if you are a commercial shop I guess but not absolutely necessary - in my case it would just allow me to make mistakes with more precision!
Surprised no one has mentioned compression fittings. I buy brake lines to get the correct flare for the fuel pump and carb ends, and use compression fittings for the filter connections. (I know they are no-no for brake lines, but fuel pressures are low enough that this works very well)
Many in my neck of the woods use cooper for fuel lines. Especially from the fuel tank to the rubber hose going to the fuel pump. Steel is used from the fuel pump to the carb.
Any thoughts on cooper?
Copper should not be used. It work hardens as it flexes or is bent, and eventually breaks (not good for a fuel line to break!).
But to be reasonable, it may take a long time for it to break.
Plasticman
Why didn't you ask this question yesterday before I did my fuel line?
Double inverted flare? First time I ever heard of that!
I guess it's back to the drawing board for me.:o
Gerry
Gerry
flaring fuel lines
Capt Roy, Make sure you read the fourth paragraph under #8 on Lars --- "How to build a fuel line " AN type fittings are 37 degrees and normally other automotive is 45 degrees , don't use a 37 degree fitting with a 45 Degree flaring tool. Most of the flaring tools you see are 45 degrees. Be careful. Hydraulic lines in industry is "AN".
You would be surprise what some people will do to fix an aircraft to save a few $$. I'm talking about private civil aviation.
I modified a standard 45 degree flaring tool to make 37 degree flares, and it worked great (in other words, sealed up tight the first time tightened, and absolutely no leaks in +5 years).
Plasticman
