Invisicord Installation - Help
Old 02-18-2008, 08:36 PM
wudturner
Support Corvetteforum!
wudturner's Avatar
Default Invisicord Installation - Help
Can anyone give me some suggestions re: getting the multi-wire connector out of the back of the rear-view mirror. Can't seem to get it out and I don't want to pull on the wires. Appreciate any suggestions.
Old 02-18-2008, 08:37 PM
FEAR
FEAR's Avatar
Yeah! Ive Had Mine On My Desk For A Week Waiting To Install
Old 02-18-2008, 08:41 PM
oakley
oakley's Avatar
Default Just squeeze
If I remember correctly there is a small tab at the top of the plug that must be squeezed. Just squeeze the tab and gently wiggle the plig and it pulls right out. I wouldn't force it. Mine came out immediately with minimal force.
Old 02-18-2008, 09:12 PM
wudturner
wudturner's Avatar
I've been doing that. It just doesn't want to come out.
Old 02-18-2008, 09:16 PM
Varmit
Varmit's Avatar
St. Jude Donor '08
In my C5 I took the set screw out and removed the mirror. Then took a small nail compressed the tab on the plug and it slid right out. On my C6 I had to turn the mirror so that I could access it better from the driver's seat. Took the same small nail and compressed the tab and the plug came right out.
Old 02-18-2008, 09:27 PM
Sativa
Sativa's Avatar
I had trouble with mine too. I pressed the tab on top and had to wiggle and really pull with force to get it out.
Old 02-18-2008, 09:38 PM
*FAÇADE*
PHOTOSHOP SPECIALIST
*FAÇADE*'s Avatar
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
The following is courtesy of Bugman's Website:
http://www.bugmanweb.com/c6/c6index.html
(Note: Refer to picture below to assure proper installation of current Invisicord.)
Old 02-18-2008, 09:47 PM
GaussianMist
GaussianMist's Avatar
I used bug man's instructions.
Old 02-18-2008, 10:15 PM
Batmbl
Batmbl's Avatar
Installed mine this past weekend. Squeeze the tab and pull out. Bugman's pics of the installation are excellent. Took all of 2 minutes. Sure works better than changing batteries in my Solo S2.
Old 02-18-2008, 10:20 PM
rothchilds
rothchilds's Avatar
if you crank your mirror down, you can do it without unplugging it also.
Old 02-18-2008, 10:54 PM
FEAR
FEAR's Avatar
Nice! Thanks
Old 02-18-2008, 10:57 PM
2005ArcticWhite
2005ArcticWhite's Avatar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11,'18,'20-'21,'24
Cool info
Old 02-18-2008, 11:06 PM
siffert
siffert's Avatar
Be very careful moving that mirror around...dont move it around very much. It has a very poorly designed cam lock system and once you move that mirror around, it then gets loose and problematic to fix.
http://forums.corvetteforum.com/show....php?t=1506173
Old 02-18-2008, 11:27 PM
0Rage@AutoBuffs
Former Vendor
Rage@AutoBuffs's Avatar
St. Jude Donor '10
Thanks for the photo directions!
Old 02-18-2008, 11:30 PM
gbgary
gbgary's Avatar
for wiring the invisicord to the mirror use bugman's instructions. last may i used the directions on the invisicord site and discovered they were wrong. after i figured out how they were wrong and posted it in this thread. they may have been corrected since, i don't know. it's yellow to pink (middle of botton row, #13) and black to black (top row) for switched operation.
Old 02-19-2008, 12:36 AM
Cal Vert Man
Cal Vert Man's Avatar
Yup, that's exactly what I did, and it was a breeze. The only other item I would do IMHO, is use a small wire tie, and tie the inviscord to the factory cord coming out of the rear view mirror plug.
Doing this helps support the invisacord wire, and reduces the chance of the inviscord being pulled out of the rear view mirror plug.
To Invisicord Installation - Help
Quick Reply: Invisicord Installation - Help
