windshield trim question???? HELP!!!
I have both pieces of the verticle trim off of the window and I see that the left is different than the right. The left is compressed at the bottom as if to make room at the bottom for the fender trim. The right side is simply cut off, tho there is still plenty of room for the fender trim.
Which is correct? I want to get this back together but I want the correct piece in there. Could some one check for me?
Thanks
Chris
Thanks
Chris
Re: windshield trim question???? HELP!!! (71roadster)
There are a couple of different ones that were used over the years so you most like have a mixed set. I have seen that before when someone replaces just one.. I had a windshield replaced once and the shop ordered new ones from the dealer and they were a little different than the originals.
[Modified by silvervetteman, 4:41 AM 12/4/2001]
