What to use to plug A.I.R. holes on Exhaust Manifolds
Old 12-03-2001, 10:07 PM
1970LT1
1970LT1's Avatar
Default What to use to plug A.I.R. holes on Exhaust Manifolds
I have a pair of correct exhaust manifolds, with A.I.R., for my 1970 350/370 engine. I want to mount them but do not have the A.I.R. system on the engine right now. What can I use to plug the holes correctly?
Old 12-03-2001, 10:13 PM
Garson
Garson's Avatar
Default Re: What to use to plug A.I.R. holes on Exhaust Manifolds (1970LT1)
I have used brass plugs I have gotten from the plumbing store. I used some thread sealer but had to keep an eye on them as they wanted to back out. I solved the problem by installing a set of Hedman headers!
Garson
Old 12-04-2001, 12:08 AM
clem zahrobsky
clem zahrobsky's Avatar
Cruise-In I Veteran
Cruise-In II Veteran
1/4" straight pipe plugs, straight pipe not the normal tapered pipe threads.
Old 12-04-2001, 12:15 AM
Captain Morgan
Captain Morgan's Avatar
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: What to use to plug A.I.R. holes on Exhaust Manifolds (clem zahrobsky)
If the manifolds are off (and it sounds like they are), then just take one into a hardware store and check the different plugs. I actually went to autozone and they had pipe plugs that fit mine. Used an allen wrench. You'll want to use anti-seize on them in case you ever want to remove them later. I plan on installing headers at a later date but wanted to remove the A.I.R. pump now as the belt was already off and it's really no use to me, just extra weight.
Old 12-04-2001, 03:03 PM
vethead
vethead's Avatar
I too used brass plugs, from NAPA. They worked great, but I look forward to replacing with headers.
Old 12-04-2001, 11:57 PM
LT1driver
LT1driver's Avatar
use the pipe plug from Loews, home depo, etc. :cheers:
To What to use to plug A.I.R. holes on Exhaust Manifolds
Quick Reply: What to use to plug A.I.R. holes on Exhaust Manifolds
