Source for matching 2007 carpet
Old 02-13-2008, 11:32 PM
papester
Support Corvetteforum!
papester's Avatar
St. Jude Donor '08-'09
Default Source for matching 2007 carpet
I'm looking for where I can buy carpet material to match the Ebony carpet in my 07 Vette. I want to use it to cover my Amp rack.
Has anybody found a good match?
Judd
Old 02-14-2008, 09:32 AM
skamp
skamp's Avatar
What you want is Truvette T912 Ebony. I got samples from http://www.accmats.com and it is a perfect match. The only downside is the backing is semi rigid so forming it may require a heat gun but for an amp rack it should be easy. It is not cheap at 60-70 a yard but it is a perfect match. Just get a free sample before you jump in. I hope this helps.
Steve
Old 02-14-2008, 10:23 AM
TheKomoman
TheKomoman's Avatar
St Jude Donor '13
Steve
Thanks Steve, good info!
I added a link to this thread to the C6 Audio FAQ.
Old 02-14-2008, 01:17 PM
papester
papester's Avatar
Steve,
Thanks. Time to get some samples.
Judd
Old 02-14-2008, 01:40 PM
skamp
skamp's Avatar
Originally Posted by papester
Steve,
Judd
Make sure to post some pictures!
Steve
Old 02-14-2008, 09:18 PM
0BOXOLOGY
Former Vendor
BOXOLOGY's Avatar
I ordered a sample from truuvette and it is a close match in color and the grain is nearly perfect, though the backing is gonna make it hard to cover your amp rack... we ended up sourcing the carpet we use from one of our manufacturers... it is a near match.. we dye it in-house to tone down the glare.
Keep in mind that all manufacturer carpet dye lots differ... and that even the truuvette has a different color from all angles, so make sure to cover your amp rack with the carpet in the right direction to match the car...gl
Nick
Old 02-14-2008, 11:30 PM
papester
papester's Avatar
Nick
Nick, Thanks for the tips. Once I receive the samples, I will decide if I'm going to cover the Amp rack with the carpet or make a fiberglass shell and paint it to match the Vette.
Judd
Old 02-16-2008, 09:49 AM
winskate
winskate's Avatar
Perfect match for 07 coupe, ebony 76" x 36" for $30. Stock # 4110
www.stockinteriors.com
Old 02-16-2008, 12:14 PM
cmb13
cmb13's Avatar
Interesting. I choose from about 10 black carpets, and although I came close, it wasn't perfect. Wish I had this info about 2 years ago!
Old 08-25-2008, 03:03 PM
TXC608
2nd Gear
TXC608's Avatar
Try www.installer.com, located in Houston, TX will ship anything.
To Source for matching 2007 carpet
Quick Reply: Source for matching 2007 carpet
