Exhaust Temp
Re: Exhaust Temp (Koz)
Koz,
Is you 80 a Calif Vette? Those sold in Calif in '80 had a 305 cu in engine. Fifth digit in VIN would be an "H" if calif car. Base L48 was "8", optional L82 was "6".
Per the Corvette Black Book, "The California RPO LG4 305ci engine included stainless-steel tubular exhaust headers with an oxygen sensor in a"closed loop" system."
tom...
tom...
Guest
Posts: n/a
Re: Exhaust Temp (Tom73)
Tom73 - Thanks for the reply.. Per my vin number my '80 is not a California model. I also have the rams horn style exhaust manifolds. Would they have installed it on all '80's and just not used it on the non-California cars?
Re: Exhaust Temp (woodworkr)
........ I have the same type exaust probe on my car. It is an ad on (same Bubba) that probably went to an exaust temperature gauge at one time. Maybe the gauge was removed or never installed for some reason (they are bad about malfunctioning). You can get a gauge that will attach to the probe from Summitt racing if you want to hook things up. It is one of the more expensive gauges though, around $150, I think. Regards, Nice car!
'74 Turbocharged 350, "Molested to Perfection" , class of '71
