AFR Heads
AFR Heads
I am seriously considering a set of AFR heads. Where is the best palce to buy them? Can you get them directly from the mfg or is their another source.
Blake-73
Blake-73
Re: AFR Heads (Blake-73)
blake
i forgot to mention 1 other way to run too much CR.
Call Comp cams, and Crane, tell them the problem and see if they can fix u up with a cam that will bleed off pressure at low rpm.
Also, BUBBA told me he could mill off the top of the pistons, no guarantee of course
Anyway i have AFR 73cc heads and they would be a good choice direct from AFR.
good luck
good luck
I am pretty sure that you can get them directly from the manufacturer. There are also a few distributors (which I think you can get from the AFR web site http://www.airflowresearch.com ).
I bought mine off of Ebay, which may be a crapshoot, but it saved me some money.
[Modified by Chris A, 2:22 PM 12/3/2001]
Blake if your looking to buy the AFR heads, Doug Herbert sells them. They are located in NC, they say they'll meet or beat anyone's advertised price. :)
Re: AFR Heads (Ganey)
Thanks for the info. I think this is the way I am going to go. I want to get the
CR just under 10:1. How much performance should I expect over my 041 cast
64 cc big valve heads?
Blake-73
Blake-73
