Turn Signal Light Bulb Replacement
Need to replace the turn signal bulb for the right front of my 2004 C5. Any "tips" to make this an easy job? Thanks for your help
light
I just did this for the first time, very easy,
1) pop up light and turn off 1 click to keep light up and light off.
2) with hood open, unscrew hood adjustment screw so your hand can fit
3) take off shroud off light, 3 screws, be careful, 1 fell but I found it.
4) reach in and replace bulb.
5) reverse order.
good luck.
5) reverse order.
good luck.
Received 19,396 Likes
'20-'21-'22-'23-'24
You guys know that you can manually raise the headlight without having to worry about it closing itself, right? I usually remove the two screws on the inside of surround with the hood up and headlight down, then raise the headlight and remove the third, outside screw. You can get a straighter shot at the two inside screws with the headlight down.
I remove the panel underneath to get at the corner lights.
The following 2 users liked this post by jss812:
BKbroiler (08-02-2020),
JimHarris4 (08-11-2020)
Unscrew the hood stop with the lights raised stick your arm down the front. Remove the locking plastic thing by turning it a quarter turn. Push the brake duct down and fish out the wiring through the hole. change the bulb. the just reverse the steps. No tools required all done by feel.
With the stock fascia, I could reach in through the brake duct opening and pull the light out that way. I can't do that with the Tiger Shark, plus I have grills in the way now. Also, you can't get both of your hand into the cavity in order to pull the bulb out of the socket. That why I extended my wiring.
Keep in might that the bulb points up (toward the hood) not out (toward the front of the car).
I actually go in through the top, like others have said. Once I remove the light from the housing, I push it down through the front air duct. It's easier to change the bulb that way, rather than trying to change it when it's stuffed down there in the well. I change the bulb, then reach back in from the top and re-insert it into the housing. Takes about 4 minutes. Good luck.
Received 1,680 Likes
Go through the access panel below!
I made the mistake of forgetting the headlight doors would close after about 15 min or so.... had my arm jammed down in there pretty good, then out of nowhere, it felt like an alligator just slammed his jaws shut around my arm. I can tell you firsthand that is NOT something you want to have happen! It hurts like crazy and if nobody is within yelling distance to come help, you have to reach around somehow, anyhow, very quickly... and manually lift (unscrew the motor drive gear) to get the housing off your forearm because your arm is stuck with no way to get it out. It pinches and hurts like hell. Trust me on that one!
That's one I'll not forget to do again! Manually crank it up in the first place!
As mentioned there are three options
Go in through the brake ducts - not easy with a Z06 or if you have screens
Go in through the bottom by taking out the bottom panel
The one that works for me is:
Turn on the headlights and back off one position to kill the lights.
Unscrew the 3 small screws on the black plastic housing around the headlight. Gently pull the housing clear. Reach down around the headlight unit and release the bulb holder. It unscrews counter clockwise but it has a plastic clip which you need to squeeze to release it. Here’s how the bulb fits into the lamp unit. The DRL bulb is the lower one.
Here’s the light socket. This one’s after market but it gives you the idea. You can see the clip you need to squeeze.
Change the bulb. Reseat the bulb holder and turn until it clicks back in place. Put the plastic housing back in place making sure to locate the small plastic tab in the bracket on the headlamp cover. Replace the 3 screws and close the lights.
10 minute job. Some guys have had the lights close if they’ve taken a while to do the fix. If you’re worried about that, disconnect the battery once the lights are up.
The bulb is a 4157NA
Some guys with big arms remove the hood adjusting screw for better access. Guys with even bigger arms have had to take off the headlight cover. Four torx screws (2 back, 1 each side). Take the back ones off first with the lamps down. Raise the lights and take the side ones out.
black match box (12-21-2015)
Are you saying, someone may forget once, (doors can close automatically) but not twice?
Did that aligator have teeth?
That's my sexy assistant. Its hard to work on a car when she's around, really hard.
There is an access panel to the light underneath there for a reason. Just drive the car up on some ramps and you can scoot under the front with a light and take your time without loosing a body part in an air duct or headlight housing. Bonus is you can also clean the crap out of your radiator intake while you are under there.
