Blower Motor ?
Blower Motor ?
Well its winter time here in NY .Im ready for all the little things that go wrong projects.So can someone tell me why does the blower motor for the ac/heater
not work on high.Im also thinking about dying the interior anybody ever do this ? good /bad cant afford to change everything so i though this might work.
Re: Blower Motor ? (ridged84)
The blower problem could be either the in-line fuse near the master cylinder (probably an orange wire with a white fuse holder). If that is not it, it will most likely be the high speed relay on the right rear corner of the engine compartment, above the blower next to the windshield wiper door switch. There are several posts in the archives troubleshooting this problem. :seeya
Phlash 72 BB Roadster
Dying your interior is not a hard thing to do, just make sure you clean all the interior parts really good with a wax / grease remover, I used a rag that was just damp with lacquer thinner. Took about two quarts of paint to do everything but the seats and carpet.
