Securing Valve Covers
Old 01-30-2008, 09:17 AM
BrettG
BrettG's Avatar
Default Securing Valve Covers
Does anyone have a good tip / trick to secure the valve covers to the head to ensure they don't leak / sweat?
Are there any good permatex products for this application?
Old 01-30-2008, 09:37 AM
zim64
Support Corvetteforum!
zim64's Avatar
I just use good 5/16 Fel-pro cork gaskets. I glue them to the valve cover, and put a light coating of cooking spray on the head side. That allows them to come off without sticking.
Old 01-30-2008, 09:41 AM
BrettG
BrettG's Avatar
Should have mentioned that I've already purchased the correct cork gaskets from LICS.
Are they prone to leaking between the gasket & head or gasket & cover?
Old 01-30-2008, 09:48 AM
Joel 67
Joel 67's Avatar
I use a light coat of RTV on the head side, then put the cork gasket down then a light coat of wheel bearing grease on the gasket on the valve cover side (again so the gasket can be resused easily).
IMHO, when these gaskets leak it is because of over tightening, an old gasket, or improper installation.
Old 01-30-2008, 11:46 AM
jim lockwood
jim lockwood's Avatar
Received 6,507 Likes on 2,996 Posts
C2 of Year Finalist (track prepared) 2019
Default Permatex Right Stuff
If you absolutely, positively don't want to see an oil leak, use Permatex Right Stuff on both sides of clean, oil-free gaskets. This stuff isn't like RTV at all. It sticks with ferocious tenacity and you don't have to wait for it to cure before returning the engine to service. It comes in an aerosol can which makes it trivial to lay down a uniform bead.
One warning, it ain't cheap. Figure on about $20 for a can.
This is the only sealer I use when building an engine and it's the only sealer I carry with me when I take my vintage racer to the track.
Old 01-30-2008, 12:04 PM
Coves4me
Coves4me's Avatar
I have always trusted Permatex products and I use a skim coat of "red" silicone sealant on both sides of the valve cover gaskets before installing on the heads. I snug up the screws and then tighten them about 3/4 turn. After about 3 or 4 cycles of engine use, I re-tighten the screws until tight, usually about a 1/2 turn. No leaks whatsoever.
Old 01-30-2008, 02:12 PM
JohnZ
JohnZ's Avatar
Received 1,856 Likes on 1,099 Posts
After making sure the seal surface on the cover is dead flat (especially around the bolt holes), I glue the cork gaskets to the valve cover with a thin bead of Permatex Hi-Temp "Ultra-Copper" RTV, let them sit overnight, then install them. Snug them up, then re-check after about an hour's run time - have never had a leaker, either with steel or aluminum covers, and the valve covers will come right off for valve adjustment without damaging the gaskets. The primary leak path is between the cover and the gasket, not between the head and the gasket.
Old 01-31-2008, 06:07 AM
aworks
aworks's Avatar
Thats the way I do it and I use the same Right Stuff. Works every time. I buy it in the small tube that fits in a small cauking gun.
Old 01-31-2008, 06:17 AM
knight37128
knight37128's Avatar
It's a big block, they don't leak like the mouse stuff.
Old 01-31-2008, 06:27 AM
aworks
aworks's Avatar
Yea right.
Old 01-31-2008, 10:00 AM
builder
builder's Avatar
Default neoprene
Does anyone use neoprene gaskets? I've had good luck with those.
I always check for a straight and clean surface too. Especially on steel covers. Most people overtighten the cover bolts too. That never helps.
Old 01-31-2008, 12:13 PM
abe g
abe g's Avatar
Default laeking valve cover gaskets cork or rubber best?
Does anyone have a source for rubber gaskets to fit 63 swc valve covers? My experience with my old mercedes with rubber valve cover gaskets show much superior to cork. PS I still use Indian shellac to seal gaskets and it still works great. (water pumps, hold in place, etc) Regards, Abe G
Old 01-31-2008, 01:36 PM
builder
builder's Avatar
Default most parts stores
I buy my rubber valve cover gaskets for my sbc's at Advanced Auto. I would assume they are readily available at most parts stores.
Old 01-31-2008, 01:39 PM
GCD1962
GCD1962's Avatar
Use steel core Perm-aline gaskets from Moroso Part #93021. Rubber molded over a steel core, you can use them over and over. Great sealing and no gook needed
Old 02-10-2008, 01:49 PM
Dicecal
Dicecal's Avatar
Which is the correct thickness cork gasket, 5/16" or 7/16"? Thanks
Old 02-10-2008, 01:58 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
i looked at the Summit catalog and it seems to indicate that the 93021 is for aftermarket heads and the 93020 is for stock heads.
Bill
Old 02-10-2008, 01:59 PM
Ironcross
Ironcross's Avatar
Most of the time it will not make any difference. The thicker gasket is a optional oversize gasket for clearance issues. The important part is correctly appling the gasket to the overhead cover to avoid leaks. Most of the replys have it covered one way or another.
Old 02-10-2008, 02:02 PM
sub006
sub006's Avatar
Unless Mr. Moto is your mechanical guru, I presume you meant "no GOOP required"?
Old 02-10-2008, 02:33 PM
OldKarz
OldKarz's Avatar
Location: On the bank of the Columbia River..... Washington State
To Securing Valve Covers
Quick Reply: Securing Valve Covers
