Wiper door mechanism rebuild....?
Since I have my windshield out, along with a total windshield frame restore, I decided to detail the wiper bay area. I removed everything and stripped and repainted the bay and it looks great.
Now, what to do with the wiper door mechanism. Aside from the usual grunge and caked on gunk, the mechanism is fine but I'd like to tear it down completely so I can sandblast & paint all the metal parts.
Has anyone completely disassembled the mechanism? And if so, any tips or advice would be appreciated. All the hinges are rivets not bolts so I would have to grind them off or drill them out. Zip makes a kit with all the rivets and bushings so the parts are available. The 4 bolts to the door broke off as expected. Can you believe those things are $6 each?
Mark
Mark
Re: Wiper door mechanism rebuild....? (mdsmith)
I tore my wiper door and stuff all aprt. At the time I didn't realize kits were available so I ended up making the bushings and one stepped screw. It's pretty straight forward. You'll probaly wish you had smaller hands and better eyesite though. ;)
I'd be interested in seeing some pics of that windshild area resto. It sounds like you're doing it without removing the front end. Is that the case?
Sounds like an interesting project. When I painted my car I left the FE on and the windshield in. I did take the chrome off the top (coupe). It looked like the top member was starting to get bad but the pillars and lower joints looked good. Anyway, I'm thinking of changing out that upper panel. BUT if I take the windshield out and there is even a little rust I will want to replace all that metal! So details of the resto would be cool!
Thanks!
Thanks!
Re: Wiper door mechanism rebuild....? (lbell101)
I'm taking some pics today...I'll post when I can.
Mark
