Pics of those 186's I bought
I don't really know what to look for, but they seem OK to me. They have 1.94/1.50 valves, and I can't visually see any problems with them. The guy seemed pretty cool and said He'd stand behind them. Guess I'll take them out to the machine shop tommorrow and have them checked out. Thanks for the replies to my other post.
Troy
Re: Pics of those 186's I bought (ORVette)
Those are the camel hump heads, same heads that were on the 350/350, 327/350, and the 350/370 LT-1. If they are going to the machine shop may as well have the valves machined to the 202/264 specs, and add the push rod guide plates as well.
Just my .02
JoeB
Just my .02
JoeB
Troy, heads look good, but can't tell much about condition from pictures.
Have machine shop remove what appears to be a broken off bolt in the accessory hole on the head on the left side of the picture you supplied. They should run a tap in every bolt hole to clean them out before and after heads are disassembled cleaned and hot tanked.
Depending on your intended usage and transmission and rear end combination, you may not gain much by going to expense of changing out from 1.94/1.5 valve size to the 2.02/1.6. If you're running an automatic with 3.08 gears, and you want low end torque, suggest you might be better off keeping the smaller valves, and just having a good three angle valve job done, with a small amount of pocket porting/clean-up done by machine shop.
Have shop check heads for cracks, and flat surface, and mill if necessary, also check valve guides for wear, and have them replaced if worn passed specs, not knulled(sp?). As I said before, if you plan to burn unleaded fuel, you'll probably want to install hardened exhaust seats, as I don't believe these heads came with them.
Also would have screw in rocker arm studs installed, but not necessary to install push rod guide plates, in my opinion, unless you plan to twist the motor pretty tight and do some serious racing. Also suggest you have 'positive' valve stem seals installed, rather than the OEM rubber umbrella seals.
Good luck, and let us know what all you had done to these heads, and what your total investment/cost ends up to be.
Received 1,469 Likes
Cruise-In II Veteran
Re: Pics of those 186's I bought (woodworkr)
Those are the camel hump heads, same heads that were on the 350/350, 327/350, and the 350/370 LT-1...JoeB
Date codes look good too. E 26 0 and F 8 0 indicate May 26 and June 8, 1970. This pair probably came off the same engine. At first glance, there appears to be too much of a gap between May 26 and June 8, but the Memorial Day holiday pops up between the two dates and the Flint facility would have been closed for the holiday.
Re: Pics of those 186's I bought (john's '81 mouse)
Good purchase! Looks like head dates of May 26, 1970 and June 8, 1970... Good dates for a late 1970 application.
John's advice is excellent and something that any good machine shop will be doing whether you ask or not (regardless, make sure you mention it). Also make sure that the machine shop pressure tests the heads as it is cheap insurance before putting a lot of money into parts and machine work.
Regards,
Re: Pics of those 186's I bought (Rowdy Rat)
Wow! Thanks for all the advice and info guys! That thing that looks like a broken off bolt is just a bolt that was left in. I pulled it out this morning and started running a tap down the various bolt holes. So far, so good. I'm going to th machine shop today to pick up another set of heads, so I'll have him take a look at these and see about doing a full blown check up before I start scheming on how to drain a few more hundred$ from the Christmas fund.
PS-Good call on the Holiday falling between the cast dates. Never crossed my mind.
