Click sound near distributor; clicks faster as I accelerate
My alternator just recently went out in my 1979 L-48, after installing a new one I began to hear this click sound near the distributor. As I accelerate the click pace increases as well. If I let off the accelerator the click stops and then continues as I accelerate. I don't seem to have lost any performance. The clicking is just annoying since I do not remember it being there prior to the alternator change. On a drive home from work I came to a complete stop and all console lights dimmed alittle and my battery guage read half way. After accelerating and driving the power returned to normal and the guage returned to normal levels. Anyone know about this clicking near the distributor? I'm not sure if it's a minor problem and soon to be major one. I would really appreciate some help on this, since my car is a daily driver right now and I can't afford it to sit in the garage due to a major problem, I'm trying to fix things as soon as I can tell, hear, or see a problem.
Thanks in advance
Thanks in advance
Re: Click sound near distributor; clicks faster as I accelerate (Phoenix79)
It sounds like you have an electrical leak coming from the cap or a plug wire.
Wait until it gets dark & start it up - you should see a spark.
Also, if you have a tach drive dist, disconnect the cable & see if the noise goes away.
Welcome to the forum :cheers:
Welcome to the forum!
I would assume with the clicking, I would say comething is hitting something. I would take the distributor apart and look for evidence of collisions inside the cap.
Re: Click sound near distributor; clicks faster as I accelerate (MikeC)
My neighbor had the same thing going on in his boat. The spark from the coil was weak and a new coil fixed it for him.
I agree with MikeC.....something amis inside dist cap.............. had the rivit let go on the rotor of my 66 big/block :eek: it happens :crazy: & the little brass thing let go ........take a good look at the inside of your dist cap ................................
If the above do not result in a find and fix, start looking at the valve train. I once chased a clicking sound from the back of a 327 for two years rebuilding dist, replacing rockers, lifters and finally ran out of options and pulled motor. It was a broken piston skirt! The broken part was held in place by the shape of the break and piston. It clicked as it changed direction in the cyl, extremely unusual.
Tyler
Tyler
Had a clicking from the same area, turned out to be the air filter hitting some other parts, as it was not installed corectly.
Received 1,875 Likes
2017 C2 of Year Finalist
Do '79's have tach cables???
I figured they were all HEI's with electronic tachs.
Jim
Jim
Get an engine stethoscope for under $20 from Sears or a poor man's version like a screw driver and listen for source. You will be able to locate whether it is inside the cap, or inside the block, etc. You can find the source very quickly with this very useful tool.
Chuck
Chuck
Thanks for the information everyone. Since I'm more than sure this clicking came right after the installation of the new alternator I'm going to assume it's something eletrical and start from there. I'll give a good look at the distributor this weekend and go from there. If I need more answers I'm sure to look for them at my new Corvette family here at Corvetteforum.com
A real newbie at cars, especially the Corvette, but I learn quick and plan to read every topic here atleast once. Thanks again everyone!
