Oil Pressure
Re: Oil Pressure (Duke94)
What is it at idol? I read some where thwat it should be about 40psi at 2000rpm. what type and grade are you using? 10W40 is what I use. What temp is the motor running at. The higher it runs at may be the problem(if there is one). in the hot summer months I use straight 40W
Brian
73 L-48
Brian
73 L-48
Re: Oil Pressure (redwingvette)
On my 1970 BB, im running at 50 psi once its fully warmed up at 2000 rpms . I use 0W30 synthetic year round. I run a cool engine : 160 degree stat , fresh air intake, twin electric fans set for 190 on and 180 off, and twin oil coolers.
RR
RR
oil pressure is 25 PSI at idle (750 RPM) warmed up (160 degrees) and 30 PSI at 2000 RPM. Doesn't sound like much of a spread.
Down here in FL with 20W50, I run about 35-40 PSI warmed up at idle and around 55-60 at 2000 rpm's. I think this is higher than it needs to be though. I do not know what the minimum requirements are.
[Modified by 79MakoL82, 10:50 AM 11/28/2001]
Re: Oil Pressure (79MakoL82)
Duke94...I think your pressure is ok. Mine, running 20W50 runs about 25 at hot idle and upper end of the scale at high rpm or "cold" oil.
