okay, okay, Here is a pic!
Cruising
Re: okay, okay, Here is a pic! (SuperFast80)
Its a Weiand SuperFlo II. When I put the Edelbrock 2101 Intake and Carb on the stock aircleaner did not fit, So I stuck this one on. Then I learned that you can get a 90 deg fitting for the carb fuel line to allow the stock cleaner to fit. Just my luck.
Re: okay, okay, Here is a pic! (cbyrd74)
Is your heater hose routed over the air compressor? Looks like a problem waiting to happen.
Another unsolicited opinion worth .02
