2004 headlights
2004 headlights
does anyone know about an adjustment that can supposedly adjust my headlight tension or something along those lines. i had a new gear installed in my headlight, besides the guy cracking my bracket on the top of the headlight but after a couple of weeks, my headlights go up just fine but when i turn them off they both go down and the one that was repaired goes back up about half way. a guy had told me there was some kind of adjustment to it, but i couldn't find anything. any help would be greatly appreciated because i don't want to take it to the knucklehead that screwed it up to begin with.
thanks, mike
thanks, mike
There's a TSB out for that and its one of the cheapest fixes on the Forum:
Number: 00-08-42-002
Subject: Left Headlamp Door Does Not Stay Closed (Shim Headlamp Door Motor/Actuator and Replace Insulators)
Model Year: 2000 Chevrolet Corvette
Condition
Some customers may comment that the left front headlamp door does not remain closed after the headlamps are turned off. Others may comment
that the left headlamp door closes when the headlamps are turned off, but then reopens. In either case, the right headlamp door operates properly.
Correction
Important
The following information applies to the left front headlamp door motor/actuator only. It does not apply to and should not be performed on
the right front headlamp door motor/actuator.
Install one washer (2) between the left headlamp door motor/actuator (1) and the mounting bracket (3) at each of the three attaching bolt locations. Also replace the
insulator (4) on each of the two mounting bracket travel stop tabs (5) as shown. For information on headlamp motor/actuator removal, see the Headlamp Motor/Actuator
Replacement procedure in the Lighting sub-section of Body & Accessories in the appropriate Service Manual.
Parts Information
Part Number Description Qty Per Vehicle
11505463 Washer 3
16524060 Insulator 2
Condition
Correction
Important
Parts Information
11505463 Washer 3
