Upper dash pad anchor locations
Aside from the upper screws on the lower dash pads and the bracket underneath toward the center next to the windshield, is there anything else that anchors the upper dash pad? According to the AIM diagram, that's it but I just want to be sure before I start disassembling.
Mark
Mark
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '03
Re: Upper dash pad anchor locations (mdsmith)
There should be clips on either side of the forward edge that clip the dash to lower windshield frame.
Dave
Dave
Re: Upper dash pad anchor locations (Rolling Thunder)
Mark
Hey Mark,
I believe you are on the right track removing that dashpad thanks to your knowledge and the other members information. I just wanted to add that in order to remove my dash, I also had to pull the driverside windshield pillar trim, and had to bend the dash in the middle a little to get it out. Regards
'74 Turbocharged 350, "Molested to Perfection", class of '71
Re: Upper dash pad anchor locations (Shutdown1)
Thanks Shutdown....I have the pillar & header trim removed already. They were rusted beyond repair due to an original top leak. I was lucky enough to get LH & RH NOS moldings off eBay for less than repros. I'm going to give the W/S frame the POR-15 treatment first though so I need to get the top pad off in order to do a thorough job.
Mark
Mark
Hey Mark,
