Crossover pipe instl and soundbyte
Moderator
Moderator
Thanks guys.....MasterDave glas-paks..hmm. Patent Pending. Drove it 'bout 20 miles today and it was worth the work.....I think... JK, I like it a lot. It was a lot of work but fun also. I figured I wasn't gonna be out much if I was going to remove them anyway. Turns out I will leave them on. The engine revs freely and with the lower tone it's more enjoyable to drive. No headache!!!
Ok, now how much is shipping from my house to your's so you can glass pack mine! They really sound much better don't they. I like my crossover for taking the bark out and giving just a little deeper note but still too loud. I think yours sound great. Not deafening!
Moderator
I'll do them for ya. I got a bit quicker on the second round (front halfs) and learned a trick or two during the process. If you're serious let me know. Not sure about $$, just time and materiel, zip is 98422.
Moderator
Yes of course. The next ones I do will be done that way. I only did 1/2at first because I thought it would be enough. It wasn't. I also was concerned with mis-aligning the header connector due to cutting too many of the chambered sections. Worked out fine as you can see and hear. I cannot stress enough the need for a balance pipe though. All the difference in the world. I'm going to Cabo Monday, be back next year......
Thought it made sense to link the full discussion with before and after crosspipe. Sounds interesting. Still like the sound of my pipes but if I ever get tired of it this may be a good way to tame them. Wonder if any of the side pipe manufactures are reading this?
Sound with out crossover pipe:
http://forums.corvetteforum.com/show...&postcount=102
Full discussion on glass packing:
http://forums.corvetteforum.com/show....php?t=1871772
I think it was mentioned previously, but anyone considering a home-brewed long "glasspack" styled sidepipe system may want to look into these;
http://www.stainlessworks.net/cart/p...roducts_id=509
They'll custom build the mufflers in any length you want (50-54" here) as well as full systems. They'd basically just be replacing the chambered section with this round tubed cherry bomb/glasspack styled muffler (I'd spec stainless steel wool packing), then welding the S-pipe and tip onto it. I'm guessing the OD of the muffler itself is in the 3.25" -to- 3.5" range. That long a muffler should make for a nice mellow tone, especially if a crossover pipe in used.
Masterdave Sidepipes
I'm reviving this thread because I just sent my Allen's 2 3/4" sidepipes to Dave to do his Masterdave patented glass pack work on them. I will try and post a sound bite when I get them back. Thanks Dave
Chambered Glass-packs
Well, got the sidepipes back from Dave and they sound great. I would guess about 25% quieter than before and deeper non-echo tone. Went for a drive and the car runs great. No performance issues. I tried to post a video but my camera resolution produces a large 148MB file so I could not post it. Maybe tomorrow I will try and lower the resolution and post a video-sound bite. My Allen's were 2 3/4" OD and now they are 3" OD. Still fit under the sidecovers but very tight. Had to do just a little adjusting of stuff but very happy with how they turned out. The guy can do some nice work! Thanks Dave!
