[Z06] Carbon Fiber Battery
Braille B2015 Carbon Fiber All Season Battery
Braille Batteries are used by racers all over the world in the FIA WRC, FIA Formula Racing, Speed World Challenge Series, SCCA ProRally Series, SCCA Regional and National Racing, NASA Touring Cars, NIRA, NOPI and Battle of the Imports Drag Racing Series. The Spec B2015 is also perfect for daily street use, even in colder climates. Braille developed the B2015 to excel at racing and to easily power street vehicles equipped with A/C, stereos and power accessories.
The B2015 features an industry leading energy to weight ratio. Enhanced Mat Technology (more surface area on the lead plates) combined with calcium full frame power path grids (increase cranking power), yields over 425 Cold Cranking Amps and 1050 Pulse Cranking Amps. With a weight of only 15 pounds/6.8kg, the B2015 is 10-30 pounds lighter than a standard battery of equal power.
Durability was also designed into the battery. Using high density oxide, braille was able to offer a battery with true deep-cycling ability over the life of the battery. Heavy duty vibration resistant power posts resist cracking and deterioration common to many lightweight batteries used in harsh automotive environments. The B2015 is a sealed unit that can be mounted in any position safely using its adjustable automotive terminal posts. Braille also includes a one-year free replacement limited warranty that is not pro-rated. The B2015 also includes pro-rated coverage over a two year period.
B2015 Carbon Fiber Battery Specs:
Casing: Carbon Composite Shell & Polymer Plastic
Weight: 15 lbs
Length: 6.8
Width: 3.4
Height: 6.1
Pulse Cranking Amps: 1067
Cranking Amps: 574
Cold Cranking Amps: 425
Amp Hour Rating: 21
Warranty: 1 Year Free Replacement / 2 Year Limited Pro-Rated Extended Coverage
Battery Type: Sealed Rechargeable Deep-Cycle
Mounting: Vertical or Horizontal
Includes Automotive Posts
Shipped with Full Charge ready to install - testing sheet included.
Recommended Uses:
Premium Luxury Vehicles
Extreme Audio Builds - Multiple Amps, Subs and enough wiring for a small city? You need this battery! Is your deisgn a work of art? Then you need this battery!
Cold Climates - Daily Driven
Custom Cars and Vintage Vehicles - No Acid to Spill protect and enhance your vehicle!
Not Recommended For:
Any vehicle you don't want to look or perform better!
Thanks
Price 228.00
NCM Lifetime # 982
$225 for the carbon fiber bad boy. Right now I'll offer $9.95 shipping on all batteries.
I have an Odessey 680 dry cell
OA Length 7 1/16"
OA Width 2 15/16"
OA Height 7 3/16"
I layed it down flat and tightened it down with the stock bolt.
$148 for this one and $10 shipping. Also 15 lbs. Not ideal for very cold weather.
OA Length 7 1/16"
OA Width 2 15/16"
OA Height 7 3/16"
Premium Supporting Vendor
OA Length 7 1/16"
OA Width 2 15/16"
OA Height 7 3/16"
OA Length 7 1/16"
OA Width 2 15/16"
OA Height 7 3/16"
It works when it's cold, it just struggles a little. The Dry cells work better when it's a little warmer. My Garage never goes below 30 degrees.
Hey by the way, can you give me some info on the katech timing chain setup. I've heard you guys sell a very nice single.
for the finished look you can order this for $75 but not absolutely necessary.
Braille Racing Battery Mount Kit Aluminum
BRAILLE UNIVERSAL ALUMINUM MOUNT KIT FOR:
B106
B14115
B2015
ALSO FITS:
B106C
B14115C
B2015C
Shows Positive and Negative Sides of battery for easy installation and maintenance of battery.
Installation of a Braille Battery with this mount kit normally takes less than 15 minutes!
Includes all Mounting Hardware!
Tool Needed:
Powered Screwdriver with Phillips Head
4mm allen
5mm allen
Note: The kit includes self drilling screws and will require the base be mounted to a firm location to be secure.
B106
B14115
B2015
ALSO FITS:
B106C
B14115C
B2015C
Tool Needed:
4mm allen
5mm allen
Hey Jason,
Define "cold". I was thinking about doing the Braille race battery at 6lbs., but was leaning toward the street battery at 15lbs. Either is a huge savings over the stock battery. My Z06 is in the garage for the winter. I don't really operate it below 50 degrees.
This one is 210. What I usually do is leave the stocker on during the off season and then put the 680 on during track days. That Braille 15lbder should be fine over 50 degrees no problem.
There is also one in between, check this one out $210
The Spec B14115 battery by Braille Auto is used by racers all over the world in the FIA WRC, FIA Formula Racing, Speed World Challenge Series, SCCA ProRally Series, SCCA Regional and National Racing, NASA Touring Cars, NIRA, NOPI and Battle of the Imports Drag Racing Series. The Spec B14115 is also perfect for daily street use. Braille developed the B14115 to excel at racing and to easily power street vehicles equipped with A/C, stereos and power accessories.
The B14115 features an industry leading energy to weight ratio. Enhanced Mat Technology (more surface area on the lead plates) combined with calcium full frame power path grids (increase cranking power), yields over 360 Cold Cranking Amps and 900 Pulse Cranking Amps. With a weight of only 11.5 pounds/5.2kg, the B14115 is 10-30 pounds lighter than a standard battery of equal power.
Durability was also designed into the battery. Using high density oxide, braille was able to offer a battery with true deep-cycling ability over the life of the battery. Heavy duty vibration resistant power posts resist cracking and deterioration common to many lightweight batteries used in harsh automotive environments. The B14115 is a sealed unit that can be mounted in any position safely using its adjustable automotive terminal posts. Braille also includes a one-year free replacement limited warranty that is not pro-rated.
B14115 Carbon Fiber Battery Specs:
Weight: 11.5 lbs
Length: 5.8
Width: 3.4
Height: 5.8
Pulse Cranking Amps: 904
Cranking Amps: 486
Cold Cranking Amps: 360
Amp Hour Rating: 15
Recommended Uses:
Daily or Race Use in Small to Medium Displacement Motors.
Weekend Track Warriors
Show Vehicles
Weight: 11.5 lbs
Length: 5.8
Width: 3.4
Height: 5.8
Cranking Amps: 486
Amp Hour Rating: 15
Recommended Uses:
Show Vehicles
Braille B106 Carbon Fiber Race Battery Lightest Racing Battery! - 6.6 Lbs 5.8"L x 3.4"W 4.2"H $190
B106 Carbon Fiber Race Battery Specs:
Weight: 6 lbs 6 oz
Size: 5.8"L x 3.4"W 4.2"H
Pulse Cranking Amps: 527
Recommended Uses:
Extreme Lightweight Vehicles
Full Race Cars
Extreme Audio Builds with Very Small Space and a need for multiple batteries
Custom Cars / Choppers - No Acid to Spill - protect and enhance your vehicle!
Cold Climates
Long Term Storage
Large Displacement Motors with High Compression
Braille B14115 Carbon Fiber Lightweight Battery 11.5 Lbs. 5.8"L x 3.4"W 3.4"H
See above
Braille B2015 Carbon Fiber All Season Battery 15 Lbs.6.8"L x 3.4"W x 6.1"H
See above
Braille B3121 Carbon Fiber Premium & Extreme Use Lightweight Battery 21 Lbs. 6.6"L x 5.2"W x 6.8"H
The Safe Bet.
B3121 Carbon Fiber Battery Specs:
Weight: 21 lbs
Length: 6.6
Width: 5.2
Height: 6.8
Pulse Cranking Amps: 1380
Cranking Amps: 742
Cold Cranking Amps: 550
Amp Hour Rating: 31
Recommended Uses:
Extreme Engine Builds - High Compression, Supercharger Systems, Large Cams, Underdrive Pulleys & No Alternators
Extreme Cold Climates - Daily Driven or Stored Vehicles
$230 for the big guy.
Weight: 6 lbs 6 oz
Recommended Uses:
Full Race Cars
Cold Climates
Long Term Storage
See above
See above
The Safe Bet.
Weight: 21 lbs
Length: 6.6
Width: 5.2
Height: 6.8
Cranking Amps: 742
Amp Hour Rating: 31
Recommended Uses:
Braille B14115 Carbon Fiber Lightweight Battery 11.5 lbs
This one has 360CCA and I've used the 680 with only 220CCA in cold weather. It starts fine with only 220 it's just it struggles a little. Basically just turns over a little longer. But with 360 you should be fine. I'll try to find out cold cranking amps on the 6lbder
How cold have you started the 680? 30 degrees? 40 degrees?
35 degrees with 220CCA. I'd go with the B14115 with 360CCA, just to be safe. I'm going to have to try it now. Plus it's a more standard size for mounting on it's side. Lower CG and removing 35+ lbs of weight for $200? Sold buddy.
