ARGH!! Well i have another days work :( Not good
As i alluded to when i asked what those lines were made of, one of the lines sheared and has a dash in it. When i tried to bleed all the fluid just came out of that one hole- which i guess is a good thing. So now i've Taken the entire hose off. I found an autoparts store that's open 24 hours a day, so i'm gonna get some wire and the flare tool, and probably a little pipe bender. Other than that i'm happy to say that i was in need of NO other tools. It's so nice to have tons of tools. Oh well. So test drive tomorrow. Bbye!
Re: ARGH!! Well i have another days work :( Not good (Jenny)
Sorry to hear you had trouble. Was this the line from the rear caliper? I have a habbit of breaking those...
But what about this 24 hour parts store? I am so jealous! I want one!
How about, you wait until Monday and we'll all run out and buy stock in the company that makes brake fluid? :D
I'm no expert at this, but I do know there's a few things you need to be aware of and be careful about when it comes to making hard brake lines. Regular (non-stainless) steel brake line is flared to 45 degrees, I think, and it needs to have a double flare. Don't take any of this as gospel. What I'm saying here is that you need to be careful when making hard lines - get good input from people that have experience making them.
Roger
Roger
24 hour auto parts store? I could really use that! I could also use all of the tools that you have. :D Everytime I do something, I find myself spending $ to get the right tool. Where did you get all these toys?! I am jealous. :p:
Cheers,
Stephen
Cheers,
Stephen
Re: ARGH!! Well i have another days work :( Not good (VolVette)
Cheers,
Stephen
Cheers,
Stephen
Brake line flaring is a double flare. Not the same as on copper lines. Best to get the right line or buy a line of comparable length and buy a bender if you don't have the right tools. Many old time parts houses will build one to fit.
Phlash 72 BB Roadster :seeya
CF Pit Crew
Cruise-In I Veteran
Cruise-In II Veteran
Almost CI III Veteran
Cruise-In IV Veteran
Re: ARGH!! Well i have another days work :( Not good (roger68)
Roger
Roger
