Do you think I had a camber problem?
Hi All,
As some know I am in the process of redoing the suspension all around on my 80. From this pic it should have been done some time ago:
[Modified by Xracer, 4:29 PM 11/23/2001]
Re: Do you think I had a camber problem? (Xracer)
From your picture if you post what location that tire came from you can easily confirm your alignment problem. Ie: LF, RF, LR, RR, as the location will confirm wether you have to much positive or negative. without knowing where it was on the car someone is guessing. :)
