why in the world is my radiator hose.....
sucking in???? i put the car in the garage tonight and the top radiator hose looked all sucked in. no pressure just the opposite. :confused: also while i was driving today there was a faint smell of coolant. i hate that smell. whats going on? low coolant? :confused:
Re: why in the world is my radiator hose..... (Vetteboy)
I sounds like when a car gets hot when shut off, and tries to suck coolant back in from the overlow. Is your rad cap good?
Dwayne
Dwayne
mine did the exact same thing but i was lucky, it finally exploded as i was leaving my drive way one day so i would recommend replacing some radiator hoses and while your doing that go ahead and do the thermostat while your in there :cheers: :cheers: :cheers: :jester
Re: why in the world is my radiator hose..... (BigBlockVette)
Dwayne makes sense. Do you have a working overflow tank? (Also called a coolant reservoir). The coolant nedd some place to go when hot and then will refill as it cools.
Re: why in the world is my radiator hose..... (SteveG75)
i think the overflow can works. i could be wrong. how do i know if it is the cap or the hose or the overflow can?
This will also happen if the radiator cap is rated at the wrong pressure. If it takes too much pressure to "open" it and allow overflow into the tank, it will close too quickly to allow the radiator to draw the overflow back in, thus creating that vacuum and collapsing the hose.
The other possibility is that the overflow hose is clogged. This would keep the water from being overflowed or drawn back. It also seems like I have heard that a stuck thermostat would cause that also, but I have no personal experience.
Hope this helps.
dl
Hope this helps.
dl
I was going to ask you that question when I saw you at Etown a couple of weeks ago! But I didnt want to be rude! :) MJ
Re: why in the world is my radiator hose..... (MNJack)
you saw it? it was doing it there? please tell me these things :yesnod: mabey that is lost horsepower :lol: i will get it straighted out this winter.
what car where you there in? did i meet you?
[Modified by Vetteboy, 9:52 PM 11/25/2001]
Aaron ( <= that's right isnt it?) I have the blue 68 convertible. Only made one pass and had fuel starvation issue (we think) resulted in 16.5 sec pass! I was hanging mostly with other sharks, ie Mike69 in the yellow 69 with sidepipes and Gordon with the red LT1 convertible with black vinyl hardtop.
Anyway, I did notice that your upper radiator hose was severely collapsed and I even mentioned it to Gordon or Mike. But it was so obvious I didnt think you needed it pointed out to you. That is reeeeeal strange that you didnt notice and now I am sorry I didnt ask you about it. MJ
i ordered a hose and a new radiator cap, so if you guys see that ever happen again you better tell me :D looks kinda funny doesnt it :D i think my car is retarted :rolleyes:
