Parts list for swapping ZZ383 crate motor into a mid year
A tach drive distributor, the oil pan off the early motor, a very low profile intake manifold and....?
Check out the archives, especially on the 2nd and 3rd points... Also check the C-3 forums, as the chassis is the same and clearances are similar. A friend of mine is putting a ZZ 383 in a C-3, so I am interested in anything you find.. My comments:
I agree on the distributor.
Lots of good manifolds will fit. Not just "very low profile".
I think the early pan will have the dip stick on the wrong side and will not fit front and rear? I understand that the supplied pan should work fine.
Also: There is a trick we discovered to fitting the GM serpentine belt system to a C-2/3 chassis. I'll add the link to the solution as an edit here...
Edit: Link is... http://forums.corvetteforum.com/show....php?t=1865159
Here's my swap list. **AIR GAP WILL FIT UNDER A SMALL BLOCK HOOD**
ZZ383 12498772
Edelbrock air gap EDL-7516
Intake gasket 12529094
Intake bolts 12550027
fuel pump(holley) 510-12-327-11
Alt. bracket (72-82 vette) 3951337
Waterpump(edelbrock) EDL-8811
Waterpump pulley shims 6129
Synchromesh Trans. Oil 12345349
pilot bushing 14061685
Dipstick 12551144
Dipstick tube 12551154
Headers(Hedman) 68286
Header gasket (felpro) 1406
spark plugs R42LTS
flywheel (168 tooth) 14091599N
Motor mounts (energy susp) 355-3-1114G
MSD distributor gear MSD8531
MSD shim kit MSD8495
ZZ383 12498772
Dipstick 12551144
spark plugs R42LTS
The 383 is a small block, So you wont have any hood cleance issues with the intake , C3 is a differnt story............ just my 2 cents I recomend MSD pro billet tach drive dist w / box........installed on my 66 BB in 1996 ........... absolutely no ignition problems......... The Dog
Here is a list of what I used:
BILLET BRACKET KIT 69600
BILLET DISTRIBUTOR CLAMP 65920
BILLET WIRE LOOMS 69520
CENTERFORCE CLUTCH OF735552 MUST USE THEIR FLYWHEEL
CENTERFORCE FLYWHEEL 700170
EDELBROCK MANIFOLD 2116
ENERGY SUS MOTOR MOUNTS 3-1114G
HOLLEY FUEL PUMP 12-834
K&N FILTER ELEMENT E-1650
LOKAR FLEX DIP STICK ED5001
MARCH ALTERNATOR BRACKET 20130
MARCH PULLEYS 6110
MSD COIL 8202
MSD DISTRIBUTOR 8572
MSD-6AL BOX 6420
PATRIOT HEADERS CERAMIC COATED 8019-1
POWER MASTER STARTER 9502
PROFORM OIL CAP 141-630
PROFORM VALVE COVERS 141-132
STREET AND PERFPRMANCE BREATHER 00001020C
STREET AND PERFPRMANCE BREATHER 00001019C
TUFF STUFF CHROME ALTERNATOR 7102RA
Dennis
MARCH PULLEYS 6110
MSD COIL 8202
MSD-6AL BOX 6420
Dennis
