Front End Suspension.
Zip sells a front end kit that includes bushings, tie rod ends, etc.. for only $159 ($40 extra for polys). I'm thinking of ordering a set. What do you guys think of the product? Anyone used these? Also, should I tackle this job myself (novice) or get someone to do it for me. How tough a job is this?
Thanks,
Thanks,
Re: Front End Suspension. (HARDNOZ)
well the hardest thing is compressing the front springs...(removal is easier obviously....)
buying a good spring compressor (internal type) or borrowing it from a local auto parts store should do the job...
a-arm bushings, take the a-arms to a machine shop and theyll install em and drill out your ball joints and drill bigger holes for the new ones for ~20-30 bucks for all 4 arms...
everything else on the frontend is easy.
im thinking you could get the frontend kit for 100 dollars on the back of corvettetrader......
Thanks,
Thanks,
Enjoy! :seeya
Re: Front End Suspension. (daily_driver)
i bought the rebuild with poly from zip about 5 yrs ago,about $170 then,x-mas special.i had no problems with their stuff.i did have a machine shop take out the old bushings and press in the new.they did not enlarge the holes however.i rented an internal spring compressor from autozone and installed the 460# springs from vette brakes &products.this is not that hard of a project and gives you the chance to clean and paint the a-arms and other components.
Re: Front End Suspension. (Gary79)
I bought the Zip front end kit from the forum Resto Store when it was on sale for about $130.00 last spring. It was the rubber kit. I have not had a problem. No squeek issues with the rubber bushings.
Dwayne
Dwayne
Edwin! ! !...Where the heck have you been hiding mate?
What would you like me to tell you about front suspensions?......I've already done mine with poly bushes and would recommend them to use as opposed to rubber for the DIY person.
At the moment I'm into pulling down the entire rear end....got grease under my nails as I type.
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Thanks,
Thanks,
It was as easy as any other suspension work. You must have the right tools and know what you are doing.
The bushings need to be pressed in and out, and that should be done by a machine shop or suspension shop unless you have experience.
The kit is the best on the market for it's price. The poly bushings are made by Energy Suspension, one of the best companies out there.
I am very happy with the improvement in my car after having done this "upgrade". I recommend you change out the springs and shocks at the same time. Plan on 2-3 days if you want to clean all the parts and re-paint them. Do one side at a time.
Re: Front End Suspension. (Brutus)
Hey there mate!
Been away and busy with the Cobra. Remember? Almost done. Been thinking about Daisy's front suspension but I did not want to be without a ride. Now that Katharina (the Cobra) is about ready, I can now start to plan the front suspension project. Bob, I'll need all the help you can give me. Not having done a front end before, I feel I need a "cook book". Tell me more about it will you?
Re: Front End Suspension. (BSeery)
Having to press the bushes in and out isn't necessary if you're going to be replacing the old ones with poly....the new poly ones just slip right in and it's quite easy to remove the rubber ones without a press. Just get a 1" wood hole saw and cut them out. It chews through them very well and you're just left with an empty shell that's simple to remove after that.
i am reffering to drilling out riveted ball joints and enlarging the holes to accept the heavy duty ball joint kits...
